turbo b18c1 revs to 5k help please
Old Oct 15, 2012 | 04:53 PM
KWPTUNING's Avatar
Default turbo b18c1 revs to 5k help please
i have a turbo 95 integra. The engine will rev to 5k and act like its hitting a rev limiter. i have my wideband running through my s300 so i have the af ratios where they should be up to that point. i have the ignition timing decreasing by .75 degree per pound of boost. any help would be greatly appreciated.
Je pistons 81.5 9.0:1
eagle h beam
eagle crankshaft
arp head studs
supertech valve springs
supertech valves
68mm throttle body
efi wizard 1000cc injectors
walbro 255
hondata s300
precision 6765
tial 44 wastegate
tial bov
aem 3.5 bar map
Old Oct 15, 2012 | 05:14 PM
mtber's Avatar
Default Re: turbo b18c1 revs to 5k help please
There are a lot of things to look at.
1. What air fuel ratios are you seeing right before & during this issue?
2. What spark plugs are you running at what gap?
3. What rpm do you have vtec activation at? What load point?
4. Do you have a launch limiter enabled? If so at what rpm?
5. What boost level is this occurring at?
6. What rpm do you have your revlimit set to?
7. Where do you have your boost cut set at?
viper_boy403
Engine Management and Tuning
16
Oct 30, 2014 04:56 PM
Randysi
Aug 27, 2011 04:31 PM
dalecrx
Mar 18, 2007 09:30 PM
doc
Aug 31, 2006 04:14 AM
PM-Performance
Feb 23, 2003 12:28 PM
