do valve stem seals affect performance?
Old Oct 15, 2012 | 08:37 AM
eg6_vti93's Avatar
Icon2 do valve stem seals affect performance?
as in title do valve stems affect performance??
Old Oct 15, 2012 | 08:42 AM
lsturbo33's Avatar
Default Re: do valve stem seals affect performance?
If they leak and oil enters the combustion chamber then it can lower the fuel octane. Yes to this example. If you mean from one brand to another are you going to make more power. Then no.
kyden's Avatar
it can, as the oil is diluting your mixture.
the underlying cause of seal failure is usually valve guide clearance, just to note.
Old Oct 15, 2012 | 09:27 PM
eg6_vti93's Avatar
thanks for that info has helped alot as i beleive my valve stems are knackered as it smokes when it hits the vtec and the power has dropped but more now that i have replaced the distributor could this also cause me loss of power?? its a brand new one but for some reason i still get cel code 9 which im led to beleive has something to do with the dizzy??
Old Oct 16, 2012 | 07:33 AM
kyden's Avatar
the china made distributors are garbage. i would find a good used oem one.
Old Oct 16, 2012 | 07:53 AM
JuicedUpRice's Avatar
here you go.
http://forums.g2ic.com/showthread.ph...e-9-D.I.Y.-fix.
Old Oct 17, 2012 | 07:31 AM
eg6_vti93's Avatar
thanks for that i shall have a a go i still have my old one so i will try combining the to to make a good one and see if this shifts the codes thanks
Old Oct 17, 2012 | 09:08 AM
eg6_vti93's Avatar
thanks for the input but its really hard trying to find one and on doing a little more research the place where i got my new dizzy from apparently have more sent sent back than accually work so i think this is definatly where my problem is
Old Oct 19, 2012 | 03:50 AM
eg6_vti93's Avatar
Originally Posted by JuicedUpRice
ok so i tried this and reset my ecu started the car and cel code 9 came straight back, although the car seems to be running a little better and my idle is sat nicley rather than to low.
what other options do i have apart from buying another new unit as i don't want to waste another £200 if the codes gonna come straight back again??? really struggling with this one
just been reading up a little more on other peoples problems and it seems that timeing can be an issue? is this correct im getting my timing belt done next week so hopefully it may solve it.
Atomic1
Mar 27, 2010 08:57 PM
chartack
Dec 6, 2009 06:27 PM
Layziebtnh055
Apr 11, 2004 07:41 AM
Ek00fbp
Oct 10, 2003 05:27 PM
sporkcrx
Jun 15, 2003 08:41 PM
