Pedal not responding.
Old Oct 14, 2012 | 12:46 PM
B33FCAK3's Avatar
Default Pedal not responding.
I have a '94 Del Sol SI with a JDM D15B Auto. OBD I, no engine codes.
The car starts, but the pedal does not respond with the throttle. Constant idle at low rpm's, no matter how far the pedal is depressed.
I can physically toggle the throttle on the engine block, and my engine revs, but not at the pedal.
When depressing the pedal, the throttle cable becomes loose at the engine.
After research I think it can be the throttle cable, throttle body, or tps. I have a digital multimeter and basic tools.
Help please.
B33FCAK3's Avatar
Default Re: Pedal not responding.
Also after looking under the dash at the pedal and cables, when the pedal is depressed it looks as though only 1 of the 2 cables is moving. But nothing appears to be loose or missing.
Old Oct 14, 2012 | 12:49 PM
B33FCAK3's Avatar
Ran perfectly fine yesterday, had trouble starting this morning due to no throttle response.
Old Oct 14, 2012 | 12:50 PM
CivicBlacksheep's Avatar
10 Year Member
Go to the throttle body... And move the butterfly... If it revs... Oviously the problem is in the cable.. Or the cable connection to the pedal.... Or the cable could be out of adjustment.. Or completely off butterfly track.... Good luck
Old Oct 14, 2012 | 12:52 PM
B33FCAK3's Avatar
That's what I meant, the butterfly does rev.
Old Oct 14, 2012 | 01:12 PM
B33FCAK3's Avatar
Figured it out, the throttle cable from the pedeal was loose around the butterfly, not the pedal. Thanks for the help, made me go look again.
Old Oct 14, 2012 | 06:21 PM
10 Year Member
Longhorn450
Apr 15, 2010 01:45 PM
theresyourproblem
Oct 4, 2007 09:28 AM
fast+forward
Sep 27, 2006 04:44 PM
sfpartseller
Apr 15, 2004 04:15 AM
Hcivic88
13
Nov 4, 2002 03:36 PM
