Troubleshooting: Fuel Pump Won't Prime
Hey guys, my 92 hatch has been sitting for 2 months so my battery is dead. But here goes, I just cleaned and tightened my ECU ground on the t-stat housing. After that, I checked the 15 amp 24 and 31 fuses and they weren't visibly blown, but I replaced them with brand new ones anyway. I then unplugged my main fuel relay and tried to jump terminals 1 and 7 and 5 and 7 with a pin, but the fuel pump still didn't prime. I just purchased a multimeter and test light earlier today, but my battery is essentially dead now. When it's charged, what's the next step? Thanks guys.
Re: Troubleshooting: Fuel Pump Won't Prime
Okay. And sorry to sound like a rookie, but I've never used a multimeter. How would I go about testing the fuel pump, and about how much voltage am I looking for if the fuel pump is healthy?
Ridin Dirty in Cali
Use google using honda-tech in the search thread when you search.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-test-fuel-pump-2774148/
I'm still confused though, sorry man. So basically, I should be testing terminal 7 since that's the fuel pump terminal? So basically I'm putting the red probe inside terminal 7 with the main fuel relay unplugged and the key in the 'ON' position? Where would I put the black probe?
1) Jump terminal 1 to 7 in the unplugged main relay connector.
2) Remove the rear seat and the access panel. Unplug the fuel pump connector.
3) Measure voltage at the Yel/Grn wire terminal in the fuel pump connector using the Blk wire terminal as ground. Repeat the test using the metal body as ground.
Key can be off because terminal 1 gets voltage directly from the battery.
The battery should be charged or jumped.
The voltage should be within a volt of voltage measured across the two battery posts.
Okay, I plan to do the test after class tomorrow. One more question, if the fuel pump checks out healthy and my ECU is the culprit, would it be safe to plug in a d-series OBD1 ECU for the sole purpose of seeing if the fuel pump will prime?
a buddy and myself had the same thing happen man. i took the main relay out and checked the solder points on the inside of the plastic cover, i believe one or two were broke so i jus re soldered them and it started right up. worth a quick look. hope u get it fixed man!
boost16awd
10
05-19-2017 10:21 AM
NovaRex
12-04-2015 05:10 PM
Pandahatch93
02-01-2005 11:59 AM
