DIY: How to fix your loose steering problems
Old Oct 13, 2012 | 10:31 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default DIY: How to fix your loose steering problems
Does your steering wheel feel loose to where at highway speeds, the bump steer can be pretty dangerous? Can you turn your wheel back and forth like this...
Yet your wheels and tires don't turn with the steering wheel?
Well I have the $30 cure for you!!! It is a special 40MM wrench you order through Honda that attaches to the lock nut on the steering rack. You will also need a 14MM open ended wrench to adjust the tightness. This works for both manual racks and power racks. I am doing this to a 5th gen. civic so should work on 94-01 tegs as well. It may or may not work for 6th gen civics.
What you need to do is jack up your drivers side and remove the front drivers side wheel to give you access to the steering rack.
You will insert the special wrench from Honda like so...
You will want to loosen the lock nut with said wrench so that you can use the 14mm wrench to tighten steering rack like so...
What you want to do is tighten the bolt as far as it goes and then back it off a quarter rotation to put it back into factory spec. You may want to adjust back or forth depending on preference of tightness. A quarter rotation was perfect for me so I didn't adjust any more. Once you get it adjusted how you like, tighten the lock nut and lower your car back down and take it for a spin. It should have the tight steering that it did almost 20 years ago and it is alot cheaper than replacing the entire steering rack!!!
I would recommend having the alignment checked out but is not necessary. I have made this adjustment to my civic as well as my lexus and neither needed any adjustment in the alignment.
Old Oct 15, 2012 | 12:03 PM
90_civichatch's Avatar
Default Re: DIY: How to fix your loose steering problems
Hey I'm new to this forum, kinda.. haha I'm not really good with computers. Either way, I seen this post and got in touch with my local Honda dealer. It should be in soon but i was wondering do you think it would be a good idea to just pull the entire rack and replace the seals and such. Also, would you know where I would be able to get a decent diagram of the rack and pinion system.
Old Oct 15, 2012 | 07:41 PM
Former User's Avatar
Here's the service manual diagram:
Old Oct 16, 2012 | 05:36 PM
gplock's Avatar
what causes a loose steering wheel ¿
Posted from Honda-tech.com App for Android
Old Oct 16, 2012 | 10:28 PM
nealnanoHX's Avatar
^^^ Age and wear in the rack.
Nice info.
Old Oct 17, 2012 | 08:06 AM
280,000 miles with the original rack can cause the loose feeling. Thanks Ron for that diagram.
Old Oct 17, 2012 | 08:15 AM
jbpnoman's Avatar
Before you go through this process, you should check your tie rod ends. Bad tie rod ends can also cause loose steering.
Old Oct 17, 2012 | 08:17 AM
low&slow's Avatar
I'm a need to do this
Old Oct 17, 2012 | 11:36 AM
Good point!!! I should note that every component on my front suspension has been updated when I swapped my knuckles to install integra brakes and also installed a ex sway bar.
New inner and outer tie rods
New upper and lower ball joints
New ES bushings
The only thing that had not been replaced was my steering rack.
Old Oct 17, 2012 | 02:02 PM
blw23's Avatar
good write up ive been wanting to try and fix this for awhile now
Old Oct 17, 2012 | 02:36 PM
BryanM.'s Avatar
Resident Gearhead
I had no idea about this. Don't remember any play though. I'll check it out.
Thanks for the heads up OP!
Old Oct 17, 2012 | 04:39 PM
yesSIR-S's Avatar
Great info!
Old Oct 9, 2017 | 07:29 PM
Brandon C's Avatar
Will this fix work on a 2010 Honda fit?
Old Oct 9, 2020 | 10:49 AM
2pac1's Avatar
Can’t you use a regular 40mm spanner?
Old Oct 9, 2020 | 02:20 PM
tony_2018's Avatar
Fish Twig
Whatever works for you. If only we knew who the 'Former User' was.....
Old Oct 9, 2020 | 08:09 PM
White_EG1's Avatar
That’d be Ron j righh
Old Jan 22, 2021 | 01:36 PM
myfavecoupe's Avatar
10 Year Member
Does this work on 6th gen civics?
Old Jan 22, 2021 | 04:15 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
It does, see below for the 6th gen FSM page regarding the rack adjustment:
Old Apr 10, 2025 | 10:49 AM
OCLC's Avatar
Amazing
I have to show my mechanic because I have new front suspension but the steering wheel still feels loose and only intermittently. This might be the trick.
Old Apr 12, 2025 | 04:06 AM
Stuckin90s's Avatar
Originally Posted by OCLC
Amazing
Heads up, I tried this adjustment on my '99 rack with 200k miles after replacing the inner and outer tie rods, but in the end the rack was too worn for any adjustment to make a difference. It is now two years later and I just had a new Edelmann (2028) rack installed (with the integra pinion mod) and the steering response and feedback is absolutely incredible. Even better than my 1990 Miata, I should have done it years ago.
rhoptry
Apr 28, 2013 07:10 PM
the_dxB16
Mar 31, 2008 11:08 PM
Eibach95Civic
Sep 20, 2007 07:44 AM
choi830
Oct 30, 2003 05:13 AM
