DIY: How to fix your loose steering problems
Location: Pensacola, FL and every Court House in Louisiana
Does your steering wheel feel loose to where at highway speeds, the bump steer can be pretty dangerous? Can you turn your wheel back and forth like this...
Yet your wheels and tires don't turn with the steering wheel?
Well I have the $30 cure for you!!! It is a special 40MM wrench you order through Honda that attaches to the lock nut on the steering rack. You will also need a 14MM open ended wrench to adjust the tightness. This works for both manual racks and power racks. I am doing this to a 5th gen. civic so should work on 94-01 tegs as well. It may or may not work for 6th gen civics.
What you need to do is jack up your drivers side and remove the front drivers side wheel to give you access to the steering rack.
You will insert the special wrench from Honda like so...
You will want to loosen the lock nut with said wrench so that you can use the 14mm wrench to tighten steering rack like so...
What you want to do is tighten the bolt as far as it goes and then back it off a quarter rotation to put it back into factory spec. You may want to adjust back or forth depending on preference of tightness. A quarter rotation was perfect for me so I didn't adjust any more. Once you get it adjusted how you like, tighten the lock nut and lower your car back down and take it for a spin. It should have the tight steering that it did almost 20 years ago and it is alot cheaper than replacing the entire steering rack!!!
I would recommend having the alignment checked out but is not necessary. I have made this adjustment to my civic as well as my lexus and neither needed any adjustment in the alignment.
Re: DIY: How to fix your loose steering problems
Hey I'm new to this forum, kinda.. haha I'm not really good with computers. Either way, I seen this post and got in touch with my local Honda dealer. It should be in soon but i was wondering do you think it would be a good idea to just pull the entire rack and replace the seals and such. Also, would you know where I would be able to get a decent diagram of the rack and pinion system.
280,000 miles with the original rack can cause the loose feeling. Thanks Ron for that diagram.
New inner and outer tie rods
New upper and lower ball joints
New ES bushings
The only thing that had not been replaced was my steering rack.
It does, see below for the 6th gen FSM page regarding the rack adjustment:
