b18c1 tune?
Old Oct 12, 2012 | 05:45 PM
elsatoso's Avatar
Default b18c1 tune?
i got a pretty nice setup when i took the car to get tune the guy dont even touch the engine idk if he can do everything from the ecu(S300) or i could get more HP we get 189hp on the wheel
Old Oct 12, 2012 | 06:11 PM
hYbRid_Eg6's Avatar
Default Re: b18c1 tune?
What's your setup? 189whp is not bad!
Old Oct 12, 2012 | 06:19 PM
elsatoso's Avatar
ARP HEAD STUD BOLTS
ARP MAIN STUD BOLTS
ARP FLYWHEEL BOLTS
ARP CLUTCH (PRESSURE PLATE BOLTS)
GOLDEN EAgle rods
JUN HEADER WITH 2.5 COLLECTOR
BUDDYCLUB SPEC 2 FULL EXHAUST
ACL RACE BEARING
HONDATA S300 (V2-VERSION)
WALBRO FUEL PUMP 255LP HP
ELDERBROCK MANIFOLD
OMNI POWER THROTTLE BODY 68MM
INJEN COLD INTAKE
ACURA RDX 410CC INJECTORS
BRIAN CROWER STAGE 2 N/A CAMS
SKUNK 2 CAM GEAR
JG PRO RACE HEA
JG DUAL VAVLE SPRING
JG TI RETAINER
PORT AN POLICH HEAD
JG OVERSIZE VALVE INTAKE 1MM OVER/.5MM EXHAUST
WISECO PISTON 81.5MM 11:5-12:1
EAGLE H BEAM RODS
STOCK GSR CRANK POLISHED
EXEDY CLUTCH STAGE 2
CRANK PULLEY
LAST 5 ARE ALL BALANCED
Old Oct 12, 2012 | 06:37 PM
hYbRid_Eg6's Avatar
ARP HEAD STUD BOLTS
ARP MAIN STUD BOLTS
ARP FLYWHEEL BOLTS
GOLDEN EAgle rods
ACL RACE BEARING
ELDERBROCK MANIFOLD
INJEN COLD INTAKE
SKUNK 2 CAM GEAR
JG PRO RACE HEA
JG TI RETAINER
PORT AN POLICH HEAD
EAGLE H BEAM RODS
CRANK PULLEY
That's about right, 189hp is not bad, what was your TQ?, what octane you using? With the wiseco pistons compression is more 11:1-11:5(they kind of made a mistake on there website awhile back, one of the member here found that out) If you want more HP get a better header/exhaust combo, intake(3in with a velocity stack?), larger cams-stage3 of some sort, but if have to becareful because you are running oversized valves. If your valves were STD size go skunk2 pro 2s you can get a little HP. What are goals? HP?
Old Oct 12, 2012 | 06:41 PM
UncleD's Avatar
You don't need to quote him, his post is directly above you.
Old Oct 12, 2012 | 06:53 PM
elsatoso's Avatar
my torqe as 129 and my goal is 220-230 if you can give me any advice i will appreciate
Old Oct 12, 2012 | 07:04 PM
hYbRid_Eg6's Avatar
220-230hp? Then you might want to start all over! Lol! Rebore/stroke to 2.0+ LS crank/rods, etc, etc. Or sell motor, buy a k20 then mod that! Or direct port NOS with current motor.
Old Oct 12, 2012 | 07:10 PM
elsatoso's Avatar
im done with the b series im moving to k series i think but thanks for the info
Old Oct 12, 2012 | 07:43 PM
hYbRid_Eg6's Avatar
Is your current motor/setup new? If so how many miles? And if new, why build the motor then give up, realistically 189whp is not that bad, maybe find a better tuner? K20 will set you back 6k-10k.
Old Oct 12, 2012 | 09:31 PM
01oemTeggy's Avatar
My build is very similar to yours cept I have a 81 (stock bore) with about 10.8 compression on skunk2 pro 2 cams. Came out to 201whp and 149tq. Get a better tuner I kno I have more to get out of mine. Going to bisI sometime in November. Eriks racing tuned it but he didnt spend much time on it (30 m mins) my vtec needs to be tuned better
Old Oct 13, 2012 | 01:12 AM
hYbRid_Eg6's Avatar
His cams are holding him back, sk2p2 are way more aggressive than the Brian crowers stage 2 but he can't run those. Better tune/tuner will at lease get him to 200 maybe?
Old Oct 17, 2012 | 05:08 PM
Julio@Bisimoto's Avatar
Congrats on your horse power numbers with your current setup, they are very respectable for a strong street car. However, it will take a bit more of an investment other than just camshafts to reach your new horse power goals.
As hYbRid_Eg6 mentioned as well, oversized valves can play a major factor when upgrading to large camshaft profiles on a b-series engines. B-series vtec valve angle is very poor in design and can cause major issues with valve to valve clearances with the combination of large lift/duration camshafts and oversized valves which may require additional head work and careful clearance checking if you stick with oversized valves.
I do agree with your choice to just moving up to a k-series engine if it is in your budget being it has larger displacement, as well a better flowing cylinder head from the factory to build upon. Just invest well on engine management with tuning.
Old Oct 17, 2012 | 06:34 PM
lsvda's Avatar
get a better tunner and dont go to bisi! my motor with the same pistons as u stock port head perfomerx intake mani ctr cams stock cams!!! rmf header 3in exhaust made 202whp and 147ft tuned on a street tune on shity free crome on 93oct usein my *** dyno so u should definly be makeing 220whp on a good tune and *** a k! u can build the **** out of a b series and spend less than a k swap
070-racing
Jul 29, 2013 04:17 PM
elsatoso
10
Sep 24, 2012 08:39 AM
akura404
Mar 3, 2006 02:12 PM
CBURKE
Jan 25, 2006 11:30 AM
mountaindewguy
Jan 20, 2006 01:22 PM
