Teggy sounds like a Subi
Old Oct 12, 2012 | 04:03 PM
tech410's Avatar
Default Teggy sounds like a Subi
Just yesterday, my car started to sound like a Subaru WRX. I have a stock B20 with GSR trans in my 96 Integra. I checked spark and compression, all is good. Swapped out spark plugs, wires, and also fuel injectors. There is voltage to all injectors (tested with meter). One thing I noticed is that #1 cylinder spark plug still looks new when i removed it after driving around the neighborhood. I guess that this is the culprit, but I can't figure out why it's doing that. Could this be due to a bad fuel rail maybe? I have also swapped out the dizzy and checked all sensors and even swapped those out.
Old Oct 12, 2012 | 05:02 PM
BC2003UGA's Avatar
Default Re: Teggy sounds like a Subi
yeah, not getting spark or fuel in one cylinder. try moving the injectors around (swapping cylinders). if that doesn't work, try the same thing with the spark plugs. should be able to narrow it down to one or the other. and hope its that, and not something more serious.
Old Oct 12, 2012 | 06:23 PM
racebum's Avatar
i have 3 sets of obd2 injectors for $25 shipped per set if you need injectors
ohm test all spark plug wires, make sure you don't have a dead wire.
injectors, wires and even a plug are possible. if you drop a plug on concrete there's a good chance it will never fire again
Old Oct 12, 2012 | 09:24 PM
01oemTeggy's Avatar
I had the same noise from my gsr. Turned out to be a bent valve.
Old Oct 12, 2012 | 11:47 PM
mouab18c1's Avatar
Had this issue recently. Faulty ecu with no CEL or anything. Car started right up everytime.
Old Oct 13, 2012 | 06:43 AM
tech410's Avatar
I'll Try those. I already tried a different ECU and still the same.
Old Oct 13, 2012 | 09:59 AM
racebum's Avatar
op said he checked compression
Old Oct 13, 2012 | 07:42 PM
wtf_is_jdm's Avatar
My ls did that once. Turns out that 2 lifters were just laying in the bottom of the head.
Old Oct 13, 2012 | 08:51 PM
01oemTeggy's Avatar
Thats great, I read that. Just merely stated what my problem was.
Old Oct 13, 2012 | 09:42 PM
racebum's Avatar
when did this thread become about you?
Old Oct 14, 2012 | 07:30 AM
01oemTeggy's Avatar
These guys did the same but your not gonna hate on them? Stfu. Have you ever thought someone else who searches could find this thread and learn from everyone who had this this noise?
If we had a thread that stated a problem with lots of possible fixes or people who say what was the problem for them it helps someone searching for this problem not to start a new thread.
Since your so good at following the forum rules why dont you "sell" your injectors in the marketplace or give him a link to your for sale thread. Listen to yourself before attempting to be "a mall cop." Hypocrite.
Old Oct 14, 2012 | 07:47 AM
01oemTeggy's Avatar
Originally Posted by tech410
Just yesterday, my car started to sound like a Subaru WRX. I have a stock B20 with GSR trans in my 96 Integra. I checked spark and compression, all is good.] Swapped out spark plugs, wires and also fuel injectors.] There is voltage to all injectors (tested with meter).
i have 3 sets of obd2 injectors for $25 shipped per set ] if you need injectors
Op said he already swapped those
So you offered injectors knowing he stated he had swapped those out. Also he stated he swapped the spark plug wires, but you still told him to do that. Stfu and gtfo.
Old Oct 15, 2012 | 05:10 AM
tech410's Avatar
I tried a diff. ecu and swapped injectors around and still same problem. Not sure what's going on now.
Old Oct 15, 2012 | 03:55 PM
wunfstgsr's Avatar
Loved
Community Favorite
sounds like your getting no spark in one or two cylinders and thats why it sounds like a wrx,
did you tripple check the firing order on the dizzy?
any chance your injector wire harnes is pinched in any area? look at it close and see if any wires may be damaged.
Old Oct 15, 2012 | 04:37 PM
tech410's Avatar
Yes, I triple checked the firing order and there is voltage to the injector wires.
Old Oct 16, 2012 | 08:57 PM
tech410's Avatar
I replaced the fuel rail and injectors again, and still same issue. I metered all the wires for voltage and there is voltage to the injectors. Any other ideas anyone want to add?
Old Oct 16, 2012 | 09:04 PM
racebum's Avatar
if you already ohm tested the spark plug wires and they all read similar for resistance, the only thing left is replacing the plugs and trying a different distributor
Old Oct 17, 2012 | 04:04 PM
01oemTeggy's Avatar
If nothing else comes up, check your valves. Check valve lash.
Old Oct 17, 2012 | 08:12 PM
tech410's Avatar
I found the culprit. There was bad continuity on the injector #1 red wire. I traced it back to the Ecu. And found that the pin on one of the connectors was pushed in and not making contact. I pushed the pin back in and that was it. Thanks for all the feedback.
Old Oct 17, 2012 | 08:17 PM
racebum's Avatar
how in the world did that happen? you have hacked up wiring'?
Old Oct 18, 2012 | 05:17 AM
tech410's Avatar
Note sure. But, feel better now. I have had this happen on a copy machine at work.
eldudepapi
Apr 20, 2017 12:00 PM
NoLeftTurn
Jul 15, 2011 08:00 PM
A2gt35r
Sep 30, 2007 06:26 PM
jdmcx
Oct 24, 2003 10:52 AM
red civic standard
Jul 18, 2002 03:13 AM
