93 del sol limp clutch
Old Oct 12, 2012 | 03:51 PM
splashy's Avatar
Default 93 del sol limp clutch
So my 93 del sol has a clutch problem, the clutch started not coming all the way up, then it got hard to shift. Now it's pretty much on the floor. By pumping it it does get pretty firm. I guess it sounds like it could be the clutch master or slave cylinder, but neither one looks like it's leaking, where else could it be leaking or could it be a different problem
Old Oct 12, 2012 | 03:56 PM
Former User's Avatar
Default Re: 93 del sol limp clutch
Check for fluid above the clutch pedal.
Old Oct 12, 2012 | 04:14 PM
splashy's Avatar
I did, it looks dry though
Old Oct 13, 2012 | 03:20 PM
splashy's Avatar
Ok, so I bled the clutch and it feels normal now, I drove it a little and it felt good. Then I realized it's leaking green fluid, it looks like it's coming from the transmission. Is this transmission oil or could it be antifreeze
Old Oct 13, 2012 | 03:44 PM
Sr420Det's Avatar
should b antifreeze, everything else is clear
Old Oct 14, 2012 | 07:32 AM
splashy's Avatar
If it's antifreeze, then where's it leaking from and could this be related to the clutch issue or something separate. Is it okay to drive leaking. Is this a minor issue or something to be concerned about
Old Oct 14, 2012 | 08:10 AM
NotAJDMFanBoy's Avatar
Clean it all up, and then you should be able to see where it's leaking from. Your clutch master or slave could both leak, the slave could leak into the bell housing, one or both could be worn out inside and not be making a seal or it could just be in need of being bled.
For antifreeze, try to find the leak and keep an eye on it. I drove my old truck around like that for a year with a slow leak I could never find.
Old Oct 14, 2012 | 08:11 AM
Sr420Det's Avatar
should b completely seperate, check ur heater hoses that r above the trans. U can rent a pressure tester from advance or autozone that hooks to ur radiator, then u pump it up to a lil above what ur cap is rated at and u should b able to c where its leaking from.
509delsol
Apr 22, 2012 01:54 PM
mikeycivics
Nov 23, 2011 05:15 PM
94SolMan
Apr 29, 2009 12:07 PM
BedDeMoN
Apr 1, 2009 03:42 PM
yaba3800
Sep 14, 2008 02:57 PM
