B16A2 - Engine won't start
Old Oct 12, 2012 | 12:09 PM
el_espiritu's Avatar
Default B16A2 - Engine won't start
Hi 2 all,
I've got a problem with my Civic Ferio, it's got the B16A2 engine and it's stock without any modifications (75.000 miles). The engine went out on Monday after smooth acceleration from a crossing with lights.
I thought it should be the ignition module, a well known problems with those engines....
But after changing the module and installing a new one the engine still does not start. I checked the fuel pressue by myself, the PGM-FI relais is working and fuel is at the fuel filter after ignition is turned on. Unfortunately I couldn't check if the ignition is working so far, I'm all allone.
Do you know any common problems except the iginiton ECU with those engines which prevent them to run?
Old Oct 12, 2012 | 12:44 PM
cmfnelson's Avatar
Default Re: B16A2 - Engine won't start
could be anything, did you check your injectors, how about your ditributor cap, idk its a difrent engine but my d16z wouldnt start one winter and turned out i had a bad seal in my distributor, and one time my fuel filter went out and i still had pressure in my fuel rail dude.
Old Oct 13, 2012 | 12:30 PM
Checked today, there is no spark at the plugs, no igniton at all. Going throuh the troubleshooting guide from the handbook I figured out that the ignition coil has not the correct resistance at all.
I have now ordered a new coil, don't know what should be else if the ignition is not working and the ignition module is already new....?!
Old Oct 13, 2012 | 01:29 PM
JuicedUpRice's Avatar
if you have no spark to the plugs,you need to check for 12v at the ylw/blk wire at the dizzy.if you have 12v,dizzy internals(anything from coil and icm,to cas and tdc sensor).if you do not have 12v,under dash(ignition switch,main relay,ecu).
coil should read .6 - .8 ohms
if the wires going to the coil wont make a circuit,you have a cas/tdc sensor problem and will most likely need to replace the entire dizzy..at least that's what mine did.if a ground isnt working to make a circuit with the other wires,look into it.
Old Oct 14, 2012 | 12:52 AM
Thanks for your post! I have 12 Volt at the yellow/black cable, already checked that.
I guess "dizzy" is distributor...?
What's the meaning of "cas", where is the tdc sensor located?
Old Oct 14, 2012 | 04:57 AM
HondaPartsHero's Avatar
Technical Hero
You should also check to make sure your timing belt didn't break as well.
Old Oct 14, 2012 | 06:07 AM
dizzy=distributor
12v at the ylw/blk with no spark to the plugs tells you it is in the dizzy internals.at this point you need to find out which internal is faulty,or if a ground isnt working,etc.
cas(crank angle sensor) and tdcs(top dead center sensor) are the two sensors deep inside the dizzy,under everything when you take the icm and coil out.
all of the wires going to the icm and coil,come first from the cas and tdc sensor.
Old Oct 14, 2012 | 08:42 AM
Thanks, I'll wait for the coil these days and replace it, letting you know the outcome!
Old Oct 14, 2012 | 06:27 PM
94accordhswaped's Avatar
Check the timing belt
Old Oct 14, 2012 | 09:26 PM
I'll do that as well, but should be the engine sounds "weird" if the timing belt it broken & the starter runs...?
It sounds absolutely normal.
Old Oct 17, 2012 | 07:06 AM
OK, it was really the coil. Replaced today, engine runs fine again
Thanks 2 all!
FATKID87
Honda CR-V & Element
Nov 9, 2014 05:51 PM
lrd27
Aug 9, 2013 06:59 PM
blk_eg4
Aug 3, 2006 08:27 PM
TaptOutTokyoB18
Jan 10, 2006 08:56 PM
Quetzolcotl
16
May 19, 2002 04:43 PM
