clutch noise?
B16 with ls tranny stage 2 exeddy clutch installed three months ago with new fidanza flywheel. When i start my car i can hear like a mild rubbin / grinding noise the. When i put it in gear thr noise goes away. Could it be the clutch forks or something?
i paid 30 for mine online, the local dealer wanted 60. if ur paying to get it installed, id suspect like 500 bucks. u could probably get it down to a lil over 100 if u remove the trans urself
Ok maybe you can give me some advice a guy messaged me from kijiji saying he has an LS tranny in good condition for three hundred should i rebuild my tranny or just throw the used one in and change the input shaft bearing
Yah im in canada so i dont know ima try and get him to 250 if not ima rebuild my tranny and be done with it i cant think of anything else other than buying a used one n throwing that in man pickins are slim up here for a decent used tranny
u mean change the input shaft bearing, cause to do a rebuild is like 400 bucks n parts. might as well change the input shaft and output shaft seals too. When i did mine i had like a hundred bucks n two bearings and three seals
Yah im at the point now where i might aswell do all bearings and seals and check the synchros i know its gonna cost a bit but i cant afford lsd nor do i know if its worth it. Btw should i get oem synchros or carbon?
Tyler Harteau
Jan 4, 2021 08:45 PM
eg_b18c
Transmission & Drivetrain
17
Oct 31, 2018 07:24 PM
