95 civic ex -- need input on engine swap
Old Oct 10, 2012 | 08:57 PM
TruD16Z6's Avatar
Icon2 95 civic ex -- need input on engine swap
i just bought a 1995 civic ex coupe....the motor that is in the car now blew driving it home and i mean blew...it has a half dollar sized hole in the block....it has a d16z6 and i dont know what motor to swap it with....i love building cars but ive always been around hot rods so dont no too much about which motor is best as far as price to power ratio...need suggestions.....would like to keep same harness and trans....dont like messing with wires. and the trans was just rebuilt and shifts perfectly
Old Oct 10, 2012 | 09:27 PM
Nicolai's Avatar
Default Re: just got 95 civic ex need help
Have the head checked and maybe resurfaced, if it is in good condition you might want to consider just replacing the block, and of course any internals in the block that are un-usable, cause I bet most of the internals are still in good condition, probably just a rod that punched a hole in the block... Anyways that would be the best/easiest route in terms of cost and work as you wouldn't have to replace anything else
Old Oct 10, 2012 | 10:51 PM
jbpnoman's Avatar
If you threw a con rod, just do yourself a favor and throw away the block and rotating assembly. You can keep the top end, assuming the engine didn't seize and snap a valve or something.
If you absolutely just want to swap the entire motor/transmission, you can either source a D16Z6 (stock replacement) or a second gen B16A, B16A3, B17A1, or B18B1. They're all OBD1 motors, and will be extremely straightforward swaps. Literally drop in motor, plug up sensors, plug in matching ECU, and go.
Old Oct 10, 2012 | 11:06 PM
TruD16Z6's Avatar
what are all the motor options i have while keeping my current harnes and trans
Old Oct 10, 2012 | 11:33 PM
jbpnoman's Avatar
D16Z6. D15B7. That's it, as far as engines worth mentioning.
Old Oct 11, 2012 | 08:13 AM
FrodeyEJ1's Avatar
if ure keeping trans then the z6 is ure best option by far
Old Oct 11, 2012 | 08:27 AM
89EFdgaf's Avatar
if i were you id stay d16z6, it will be your cheapest and easiest fix to your car, do you know why your engine blew tho?
Old Oct 11, 2012 | 11:08 PM
TruD16Z6's Avatar
im pullin the engine apart currently tryin to figure out wat made it blow like it did
Old Oct 11, 2012 | 11:57 PM
1siccrx's Avatar
depending on where you live you can pick up a z6 bottom end or a whole motor in that case for pretty cheap
Old Oct 12, 2012 | 12:39 AM
TruD16Z6's Avatar
i live near fort wayne indiana....ive called local junk yards and they dont even have civics
Old Oct 12, 2012 | 09:33 PM
1siccrx's Avatar
did you check the craigslist for around there?
Old Oct 12, 2012 | 09:48 PM
slowb16turbo's Avatar
any d series bottom will work and they are super cheap
Old Oct 12, 2012 | 09:49 PM
TruD16Z6's Avatar
yeah i found another d16z6 bout a hour away goin to check it out sunday but even craigslist is pretty bare because there isnt much of an import scene here
Old Oct 13, 2012 | 08:26 AM
1siccrx's Avatar
Default Re: 95 civic ex -- need input on engine swap
Ok sweet good luck hunting lol
Bense
454
Jan 26, 2024 03:11 PM
Vtrp082808
Feb 20, 2013 04:02 AM
Juk3zz
Oct 7, 2010 06:27 PM
chuck75
Jul 17, 2010 04:42 PM
clampjaw25
May 10, 2007 08:24 AM
