Starting problems now with swap
Old Oct 10, 2012 | 06:12 PM
hondaaccordf23's Avatar
Default Starting problems now with swap
00 Accord H23a Vtec with a chipped p28 h22 basemap
So I converted from 3 wire IAVC to 2 wire had car on not realize it(on position engine not running), blew a fuse, replaced fuse.
Now my car is throwing code 9 which is Cylinder position sensor no power to etc... Check with a DMM 335 ohms, recommend is 350-700. I am not sure if it is the sensor or the wiring. I have checked conversion harness every is good except when I wiggle the wire on B plug and I hear a click with key on the on position sometimes it trys to start which is weird to me.
Now my problem is the car is starting hard and then dying.
As the video shows
http://www.youtube.com/watch?v=DHI_X...ature=youtu.be
Old Oct 12, 2012 | 11:56 PM
holmesnmanny's Avatar
Default Re: Starting problems now with swap
So how's the continuity from that pin on the connector to the distributor connector ? Try wiggling it while seeing if continuity holds.
Obv the sensor tests below specs. You can either try to get another sensor or just try another distributor.
Jayrayk
Jan 13, 2019 06:27 PM
hondaaccordf23
Oct 15, 2012 08:19 AM
95lscivic
13
Nov 4, 2008 11:19 AM
2ToneEM1
Oct 9, 2008 12:03 PM
Ron454321
Aug 27, 2007 07:43 PM
