Need help, it's been bugging me
Old Oct 9, 2012 | 09:57 PM
Ride Da Fire's Avatar
Default Need help, it's been bugging me
I finally had the engine put back together and installed into the engine bay after 13 months working on it. Everything fine for now.. except for the COOL FANS and Engine oil cooler. I bought a 97 JDM GSR from HMOTORONLINE and converted to OBD1. I have replaced the cool fans to slim cool fans and also replaced the relays, fan switch at the thermostat housing and checked all the fuses, still the fans won't come on at all. All ground points are checked and good to go I couldn't think of anything else. 2nd I've done enough researching and find that the 96-97 JDM GSR does not come with engine oil cooler, the engine oil run thru the big coolant oil line I think... (i'm still very confused) should I get an aftermarket or find an OEM engine oil cooler at the junkyard and install it or it's good the way is it right now? thanks in advance.
Old Oct 9, 2012 | 10:34 PM
mouab18c1's Avatar
Default Re: Need help, it's been bugging me
Is your car overheating?
Old Oct 10, 2012 | 06:14 AM
I took out for a test drive around the block and I noticed the Temp gauge needle was right in the middle between hot and cold... I should be sit somewhere closer to cold than hot... I'm think direct wires to the battery and make a switch for it...
Old Oct 10, 2012 | 10:45 AM
vtecdc4's Avatar
could be your thermostat, they are known to malfunction in integras, at least all 4 of mine
Old Oct 10, 2012 | 11:58 AM
JuicedUpRice's Avatar
i bypassed mine by wiring it into the cd player power wire.when i turn the key to first click,it comes on automatically.
Old Oct 10, 2012 | 12:04 PM
vtecdc4's Avatar
jump the fan switch with a little wire or somthing see if the fan turns on
Old Oct 18, 2012 | 06:35 PM
Thanks... you wouldn't believe it but I had air trapped in the heater core... I dumped out all the coolant, replaced it and let the car run with full heater blast, coolant heated up, a bunch of bubbles came up, after awhile I don't see bubbles anymore, I refilled the coolant...... 3 mins after the fan kicked in..... thanks guys......
jack cohen
Jul 25, 2017 05:51 AM
76 camaro car
Oct 21, 2013 01:26 PM
sorullo
Jun 18, 2008 06:38 PM
pos_cd5
Jul 23, 2006 10:43 AM
