Dome light supervision relay question, bad place for a diode?
Old Oct 8, 2012 | 01:06 PM
Canadian_EF's Avatar
Default Dome light supervision relay question, bad place for a diode?
I wired up my relay but my dome light supervision doesn't work. Dome light is active and working when door is open or turned on manually. I hear the relay click 30 seconds after ignition disengages, so it is functioning, ground is good, power is good.
I spliced the dome light wire, coming off the relay, into the door trigger wire coming off the alarm. there is a diode on it as my trunk trigger shares that wire as well (it also has a diode).
Is that diode my problem? Should I tap in so it isn't isolated by the diode, but keep the alarm's door trigger wire isolated???
Alarm: Viper 5900
Thanks.
rugimpy
Audio / Security / Video
Dec 4, 2009 08:05 PM
pudder
Dec 31, 2007 11:21 AM
suspendedHatch
13
Apr 28, 2004 07:50 PM
TheIntegraGuy
Sep 25, 2003 10:18 PM
civicmark
Jan 2, 2003 11:31 AM
