Need help finding a certain connection. (wiring)
Old Sep 24, 2003 | 11:17 PM
TheIntegraGuy's Avatar
Default Need help finding a certain connection. (wiring)
I'm in the process of installing an alarm on my car. It's just a generic alarm just to help me out a little. Anyway, I would post in the Audio/Security forum but I never get any replies so I figure I'll get more answers in here, the Integra forum..Being that I have one.
Anyway, I got every problem figured out except for one. I can't seem to find the connection for the dome light. My problem is: I need to find the easiest and closest connection access to the dome light so that when the dome light turns on, the alarm goes off. I "could" Mickey-Mouse" it and run a wire from both door triggers, but I figure if the dome light comes on, it'll be much easier.
I already know what wire I have to use to connect it to but I don't know where the connection is that I should make. Does anyone know where the dome light wire connection is. Perferably around the steering column or near/by the fuse box?
-Thanks
Old Sep 25, 2003 | 01:38 AM
Kp_VtekNiks's Avatar
Default Re: Need help finding a certain connection. (TheIntegraGuy)
On my alarm, I connected the door trigger wire to the driver's side door switch wire. It was a Green/Red wire that runs through the driver's side door sill to the kick panel. With that connected, even when passenger's side door is opened, the alarm goes off.
Old Sep 25, 2003 | 09:02 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
There is a harness up inside the driver side kick panel, near the cruise control brain box. This harness contains the power door lock wires (I assume you know which one that is), and also contains a wire for the domelight. I know because when I unplugged it to try to diagnose a problem I had w/ my alarm not locking the doors, the domelight also went out. I don't know which wire exactly it is, and I don't have my Helm's manual handy, but you should be able to find it.
Old Sep 25, 2003 | 10:18 PM
Default Re: Need help finding a certain connection. (PatrickGSR94)
Thanks guys... I'll be sure to look out for those two parts.. Does anyone else have any tips?
-Thanks.
kjrayo18
Jul 21, 2014 06:47 AM
crx88ia
Jul 23, 2012 04:41 PM
EJ8 GSR-T
Aug 5, 2005 04:27 PM
suspendedHatch
Audio / Security / Video
13
Apr 28, 2004 07:50 PM
civicmark
Jan 2, 2003 11:31 AM
