b swap problems
Hey everyone im new on here but anyways ive been workin on this b18a1 swap into my EF hatch its been previously converted to obd1 and the motor was obd0 i put the injectors and dizzy and altenator on it but its bogging out and now it wont stay running im lucky if it'll even start im really getting frustrated with it idk if idont have something hooked up right but i would appreciate any help that can be offered
check it grounds first. trans to chassis, valve cover to chassis, thermostat ground. if still nothing check ur iac, take it off spray sum carb cleaner n let dry for a while, if its an a1 u should have a fitv under the throttle body. remove and disassemble. easy. then wen u reassemble tighten all the way down. let me kno how it goes.
Posted from Honda-tech.com App for Android
jdm ef9 hatch
Apr 18, 2010 02:38 PM
nickeynick
Jun 29, 2009 08:52 AM
