ARP head studs....
Old Oct 17, 2002 | 12:37 PM
baonest1's Avatar
Default ARP head studs....
does ARP make these, ive searched and only found the head bolts. i was told if i use head studs then i dont have to relocate my dowel pins on the ls/vtec. can someone confirm this.
thanx
Old Oct 17, 2002 | 01:00 PM
sgT's Avatar
sgT
Default Re: ARP head studs.... (baonest)
the dowel pins are necessary to properly located the head.
ARP studs do not do this. They hold the head down to the block.
Old Oct 17, 2002 | 01:08 PM
baonest1's Avatar
Default Re: ARP head studs.... (sgT)
ohok. so ill use them then. but they have ARP studs out dont they.?
thanx
Old Oct 17, 2002 | 01:18 PM
sgT's Avatar
sgT
yes. for a long time now.
Old Oct 17, 2002 | 01:32 PM
JDMPARTS4U's Avatar
Forget
ARP head studs get AEBS head studs there way thicker and dont stretch also I think ARP makes them for AEBS anyways go check them out they also have a little piece at the bottom to help friction with torquing them down so they fill up the entire area
Old Oct 17, 2002 | 02:34 PM
D's Avatar
D
Default Re: ARP head studs.... (TheRiddler)
ALL bolts/studs stretch.
D
Old Oct 17, 2002 | 02:38 PM
Tommy_Gunns's Avatar
Default Re: ARP head studs.... (D)
I concur
Old Oct 17, 2002 | 02:45 PM
NW94RS
Guest
Posts: n/a
Default Re: ARP head studs.... (Tommy_Gunns)
aebs over apr Hmmm
Old Oct 17, 2002 | 02:56 PM
baonest1's Avatar
Default Re: ARP head studs.... (dc-2R)
so i found them on inline four. should i get b18b, or b18c.?? its for lsvtec.
Old Oct 17, 2002 | 02:57 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Import Builders would probably have them in stock.
Old Oct 17, 2002 | 03:01 PM
Smitdog's Avatar
Default Re: ARP head studs.... (vtecvoodoo)
Old Oct 17, 2002 | 04:20 PM
baonest1's Avatar
Old Oct 17, 2002 | 04:27 PM
rainmanEK's Avatar
big strong guy
b18c1/5 being you will using vtec head! eric
sgT's Avatar
sgT
b18c.
Old Oct 17, 2002 | 06:29 PM
baonest1's Avatar
thanx
PhrequenC
Jun 9, 2008 10:55 AM
b16a4
Feb 9, 2007 07:22 PM
9seccivicsi
Sep 20, 2004 10:55 AM
Nextelbuddy
Feb 26, 2004 11:46 PM
civcexcoupeblack
Mar 23, 2003 01:22 PM
