#14 fuse blows hitting redline
Old Oct 5, 2012 | 11:45 PM
BIGef's Avatar
Default #14 fuse blows hitting redline
89 civic b18 obd1 swap
Bone stock
Ngk spark plugs
Fireball external coil
Ghetto rigged dizzy cap
Well i test drive the car driving at normal speed. Shifting at 3k.
Everything checks fine
Put when i put the rpm at 7k+ or redline
#14 fuse always blows??!!! It is the alternator fuse
It ends up not starting so i had to replace the fuse on the spot
Then it starts right up
What could be the prob?
Old Oct 6, 2012 | 06:43 AM
Former User's Avatar
Default Re: #14 fuse blows hitting redline
Have the alternator tested.
Old Oct 6, 2012 | 06:56 AM
Swap'DShuttle's Avatar
Had this problem when putting load on my engine quickly. It would move just enough to short the alt wire on the case. Check that your charge wire is secure.
Old Oct 6, 2012 | 12:58 PM
tonylovesjdmEF9's Avatar
ghetto rigged dizzy cap lol
Old Oct 6, 2012 | 02:37 PM
BIGef's Avatar
how many volts should it be?
ill see if its secured thNks
yup lol
Old Oct 6, 2012 | 02:50 PM
bryse68's Avatar
i had the same problem, was my alternator.
Old Oct 7, 2012 | 02:32 AM
BIGef's Avatar
tested the battery and alternator i think it checked out good.
battery car off-12.13
battery car on-13.93
alternator car on- 14.37
Old Oct 7, 2012 | 07:52 AM
Redo you voltage tests at high engine rpm.
Fuse 14 protects the alternator, fuel pump, IACV, ECU, and EVAP solenoids.
Old Oct 8, 2012 | 03:15 AM
BIGef's Avatar
Redid my voltage test and it doesnt really change.
It is at 14.30 and it changes by a little like 14.32,14.29
Revved at 4k rpm+
latino honda
May 24, 2019 11:32 AM
civiccoupe94
Sep 19, 2008 01:27 PM
CRISWHITEBOY
Jun 17, 2008 11:46 PM
ppfalcon
Dec 11, 2005 01:14 PM
95gsr
Sep 18, 2001 09:25 AM
