Are there any differences between H22 and H23 bearings.../
Old Oct 5, 2012 | 08:18 PM
nemesis25's Avatar
Default Are there any differences between H22 and H23 bearings.../
Like the title says. I'd like to know if any differences exist between these two main and rod bearing sets; H22 and H23.
Thanks.
Old Oct 6, 2012 | 07:15 AM
nemesis25's Avatar
Default Re: Are there any differences between H22 and H23 bearings.../
Besides the part number
Old Oct 7, 2012 | 07:28 AM
v4lu3s's Avatar
RTFM
depends on the year. 97+ h22 mains are bigger for 55mm mains compared to 50mm.
other than that the f22, h23 and h22 bearings are all the same.
Old Oct 10, 2012 | 07:12 AM
snobordboy's Avatar
Moderator
^ yup.
As long as you make sure you have the correct main size (either 50 or 55 mm) all H22 bearing sets will work for an H23 as well.
Old Oct 10, 2012 | 03:03 PM
nemesis25's Avatar
Originally Posted by snobordboy
^ yup.
Thanks.
Old Oct 18, 2012 | 04:09 AM
VtecKiller32's Avatar
h22a is 50mm main journals
h23 is 50mm main journals
h22a4 is 50mm main journals (on 1997 models only)
h22a4 is 55mm main journals (on 1998 and up)
so to answer your question yes there is a size difference between h22 bearings and h23 bearings.
prelude_93vtec
Oct 23, 2008 12:27 AM
vteg94
Aug 23, 2007 09:25 PM
eagleclawracing
Sep 12, 2006 10:38 AM
trev4
Jul 21, 2004 10:25 AM
LudeSi-93
Jul 19, 2001 12:50 AM
