resleeving H23A ?
Old Jul 17, 2001 | 03:04 PM
LudeSi-93's Avatar
New User
Default resleeving H23A ?
I'm planning on building the WHOLE bottom end up on an H23A. Planning to get some ductile iron sleeves. Has anyone done this or can give me some advice? Thanks
Old Jul 17, 2001 | 08:01 PM
boomslang's Avatar
Default Re: resleeving H23A ? (TurboLudeSi)
Blownlude is having his H23 resleeved and assembled by Golden Eagle for 900 bucks.
If you are gonna get serious, you might want to consider decking your block and getting custom rods made. It will vastly improve the rod/stroke ratio. If you don't want to do that, destroking is possible via an H22 crank. With the H22 crank, rod/stroke ratio will be improved slightly over an H23. The stock H23 rod/stroke ratio is shitty at best.
Use the piston oil squirters that are in the H22.
Old Jul 17, 2001 | 09:04 PM
TurboInteg95's Avatar
Default Re: resleeving H23A ? (Inlinefour)
what's the rod ratio on the H23? what is it on an H22?
Old Jul 18, 2001 | 09:10 AM
boomslang's Avatar
Default Re: resleeving H23A ? (TurboInteg95)
H23 is 1.49
H22 is 1.58
Old Jul 18, 2001 | 12:58 PM
Wow, that's a pretty *** rod ratio. That's even worse then an LS. Hmm, not sure what to say about that.
Old Jul 18, 2001 | 01:09 PM
LudeSi-93's Avatar
New User
What is the length of the rods in the H23A vs H22A ?
Old Jul 18, 2001 | 08:09 PM
boomslang's Avatar
H23 is 141.5mm, H22 is 143mm.
Old Jul 19, 2001 | 12:50 AM
kawgomoo's Avatar
oh dear god. people..rod ratio isnt all that its cracked up to be. that *** rod ratio is why the lude has a fairly good torque curve. there are trade offs for everything...and larry's obsession with r/s ratio isnt the end all be all of motors.
oh yeah.. if you plan to run a forged piston relseeving is a definate must do. stock aluminium cylinders are poop. at least b series have iron. hmmph.
anyhoo our bill for sleeving was about 500 using ductile sleeves.
EGeek
Oct 7, 2011 04:37 AM
x22xhyper
Sep 18, 2008 06:42 AM
vteg94
Aug 23, 2007 09:25 PM
ge_itr
Feb 8, 2007 01:26 PM
JDMBB2
Nov 13, 2003 10:39 AM
