Wont pass 3k rpm
Old Oct 5, 2012 | 07:15 PM
White_hatch23's Avatar
Default Wont pass 3k rpm
Whats up everyone, so i have a problem today i installed my skunk2 intake manifold and throttle body i have all the lines connected and everything how its suppose to go, besides the tps i still have to calibrate it but now my car doesnt rev pass 3k rpms
Old Oct 5, 2012 | 08:08 PM
Ryan Lwin's Avatar
Default Re: Wont pass 3k rpm
Maybe your throttle isn't opening all the way.
Old Oct 5, 2012 | 09:40 PM
jbpnoman's Avatar
You already know one thing that's wrong - you admitted you haven't calibrated your TPS. Do that, then get back to us.
Old Oct 6, 2012 | 03:52 AM
grumblemarc's Avatar
The Grumpiest
Correct all known deficiencies before reporting an issue to have solved. Once all deficiencies are eliminated then you might find your issues will be gone.
Old Oct 8, 2012 | 09:36 AM
LadyCamouflage's Avatar
I'd say TPS.
Old Oct 15, 2012 | 05:32 AM
I calibrated my tps sensor.yesterday.and also I don't think it's that because it's new
Old Oct 15, 2012 | 05:36 AM
jbpnoman's Avatar
"New" only means that it definitely needs to be properly calibrated. They don't come perfectly set out of the box.
Make sure your throttle cable slack is adjusted correctly. Did you convert from a Y7 style IM, or just upgrade from a Y8 style manifold? If you upgraded from a Y7 style manifold, did you replace the throttle cable with a proper Y8 cable?
What engine do you currently have in the car? What other mods? What ECU? Do you have any CELs?
Old Oct 16, 2012 | 01:18 PM
i have a b20z2 with a p75 ecu obd2, the throttle cable is the original one, i do have a cel i drove the car to autozone today to get it checked out these are the codes that came out
p0135-faulty A/F sensor 1
p1508-failed IAC valve
p0113-faulty IAT sensor
p0122-faulty Tp sensor
also not sure if i calibrated the tps right
Last edited by White_hatch23; Oct 16, 2012 at 01:26 PM. Reason: forgot to include something
Old Oct 16, 2012 | 02:24 PM
Heres a short video of what the car does.
http://www.youtube.com/watch?feature...=2pyh_qjTQcw#!
Old Oct 17, 2012 | 01:03 AM
jbpnoman's Avatar
What motor was originally in the car? If it wasn't a Y8, you have the wrong throttle cable.
So your primary O2 sensor is shot, or the wiring is messed up. Check the wires for nicks/dings. If it doesn't look damaged, voltage test it. A how-to is in the FAQs sticky.
IACV isn't working correctly. Make sure it is plugged in. If it is, take it out and clean it. If that doesn't help, voltage test it. Once again, how-to in the FAQs sticky.
IAT isn't working correctly. Make sure it is plugged in. If it is, voltage test it. Once again, FAQs.
TPS isn't working correctly. You may have calibrated it incorrectly, or you might have gotten a bad unit.
Also, it's possible that you plugged the wrong things in the wrong places. Post the colors of the wires running to your IACV, IAT, and TPS.
Old Oct 17, 2012 | 05:52 AM
purgat0ry's Avatar
This
Quite a few of those plugs are identical looking; the underlying wires will tell the truth.
Old Oct 17, 2012 | 06:05 AM
mathai's Avatar
if it won't go pass 3k, that means your car is in limp mode. is the check engine light on? see if its throwing any codes.
silviaEP3
14
May 10, 2012 06:35 AM
integrainside
Jan 25, 2010 07:07 PM
integrainside
10
Apr 29, 2008 11:50 AM
citystars41
Jan 10, 2008 09:58 PM
Wazup
Feb 21, 2006 11:26 AM
