94 Coupe/GSR swap - horrible gas mileage and cracked distributor cap
Old Oct 5, 2012 | 05:41 PM
Wilka's Avatar
Default 94 Coupe/GSR swap - horrible gas mileage and cracked distributor cap
Car is getting horrible gas mileage and I may have a cracked distributor cap, I just replaced the fuel filter and getting new fittings and hoses for my new fuel pressure regulator, I can't figure out why, the idle is also horrible, I tried disconnecting the iacv from the back the manifold and adjusting the idle screw but still idles at a steady 1400 or at a redlight all it does is fluxuate from 1400 or so to 2300 and go back and forward and can be quite annoying, along from my misfire probly from the distributor I can't tell why its burning so much, its running really rich, you can practically get dizzy from 2 cars behind me, but I don't smell fresh unburnt fuel or see any leaks even under fluxuating throttle to go threw pressure changes and can't find anything. Thanks for the help.
Old Oct 5, 2012 | 08:55 PM
Wilka's Avatar
Default Re: 94 Coupe with obd1 GSR swap
NOBODY can shed any light on this?
Old Oct 6, 2012 | 08:30 AM
Wilka's Avatar
bump
Old Oct 6, 2012 | 08:36 AM
94dxcoupe's Avatar
Any check engine light?
What ECU?
When did the problem begin?
More info would help...
Old Oct 6, 2012 | 08:38 AM
Ej8-GSR's Avatar
Try replacing it it or check that u don't have a vacuum leak like from ur map sensor. Mine had that problem and it was the iacv gone bad. See if u can test it
Old Oct 6, 2012 | 08:44 AM
flash0124's Avatar
are you sure its firing on all four. if its missing on one, it will kill your milage and put out a ton of fumes. check all the plugs when cranking make sure they all fire.
Old Oct 6, 2012 | 09:04 AM
Wilka's Avatar
Iac is pulling vaccum from the throttle body hole, vaccum leaks, didn't find any, when the car first starts it idles fine, I can rev it to 3 and then when it comes back down, just bounces.
Old Oct 6, 2012 | 09:05 AM
Wilka's Avatar
I pulled out the spark plug wires and they're all sparking when held with a screw driver against the valve cover.
Old Oct 6, 2012 | 09:10 AM
flash0124's Avatar
have you check the actually plugs and not just the wires, my car had crap old plugs when i first got it and it reacted similarly until i replaced them.
Holysmoked84's Avatar
So ur idle always hunts?Or did it just start out of the blue?Did u drain the rad recently and not bleed the air out the car ?it will have a hunting idle if u don't properly bleed e cooling system
Old Oct 6, 2012 | 09:14 AM
Wilka's Avatar
To bleed the cooling system you just start it with the cap off and let all the bubbles cycle and come out correct? And no I didn't actually pull the plugs but I just did spark plugs maybe 3 months ago.
Old Oct 6, 2012 | 09:16 AM
flash0124's Avatar
when did these problems start. how well was it running before.
Old Oct 6, 2012 | 09:32 AM
Former User's Avatar
Default Re: 94 Coupe/GSR swap - horrible gas mileage and cracked distributor cap
Please create a thread title that summarizes your technical problem/question so that members may quickly understand the topic without reading your post. This helps you to get more and better responses by letting our members know what technical information that you need -- Title edited.
Old Oct 6, 2012 | 10:41 AM
DCRB's Avatar
take your fitv off and adjust it closed like this thread.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/.
your cracked cap shouldn't even be a question. replace that. and the rotor. and your plugs.
make sure you're not throwing any codes.
also try swapping injectors out with another set, you could have a stuck injector.
Old Oct 6, 2012 | 03:20 PM
skuded's Avatar
I would start by replacing the plugs with the proper ngk's i think its bkr8's i may be way off on that its been a while but thats the proper ngk plug for your motor, if you already have the correct plugs installed by correct i mean the plug mentioned above and none else did you check for proper gap on the plugs, the distributor cap i wouldnt worry about yet unless its actually cracked through causing poor contact with the rotor
Old Oct 8, 2012 | 08:34 PM
Wilka's Avatar
Comes to find out it was an o ring in the injector slot of the intake manifold, I replaced the o rings and reset the ecu and the misfire even went away, but for the sake of argument I am replacing the ignition coil, cap and rotor as this is probably the first time its ben done in over 18 years for the motor. I will also clean the fast idle air valve even though the idle hunt has now stopped as well, I think it was just like air getting past the rubber so it was almost like a bad vacuum leak along with the exposed ever so evaporating quickly gasoline.
Old Oct 8, 2012 | 08:35 PM
Wilka's Avatar
Thanks for the help and suggestive things though guys!
whtteg10
Jun 29, 2014 01:44 PM
CircuitFG
Aug 18, 2005 04:40 PM
civcexcoupeblack
May 22, 2003 06:44 AM
DSeriesBeeKilla
Apr 13, 2003 09:53 AM
si95
Sep 5, 2002 11:42 AM
