92 civic dash lights not working
Get an ohm meter and put one lead on the wire that should be ground and the other lead on ground. If there's continuity, it'll be 0 ohms, if there's a dirty connection, the ohms will read a number, but if there's no continuity, the meter won't change at all.
Ok so found out the is a good ground its the power im gettinng no power any body know what could cause there to be no power the fuse is good how bout the switch how could i test that? Also my parking lights are not working front and back.
osseau
Sep 7, 2017 08:07 AM
rsx03
Nov 6, 2002 04:04 AM
