dumb question, quick answer piston help
Old Oct 4, 2012 | 10:41 PM
dommyy13's Avatar
Default dumb question, quick answer piston help
I'm looking to get my block bored/honed soon and I'm shopping for pistons. Why are there 2 specifications for the size? I'm looking at srp pistons and it says 81.25mm (the bore size I plan on getting) and then it says +0.020 oversize. What does the oversize mean?
Old Oct 14, 2012 | 09:49 PM
jeffkong11's Avatar
Default Re: dumb question, quick answer piston help
it refers to oversized compared to stock size, thats .20 over oem standared bore
Old Oct 15, 2012 | 03:13 PM
discountparts14's Avatar
If your stock pistons are 81.mm then 81.25 is fine.
+0.020 simply means 20 thousandths over stock bore.
81mm is OEM bore so .25mm or 0.010 thousandths of a inch is the area/meat you have to work with in the cylinder to do the clean up hone considering your piston wall setting.
If your cylinders are scored or out of round you may need to go to 0.5mm over.
Most piston manufacturers make pistons slightly over OEM / stock bore size for rebuild customers like yourself.
Depending on the type of material your cylinders are made of and final piston wall clearance you decide on as well as the application turbo or N/A of your build. All those things need to be taken into consideration before you purchase pistons.
user 98292739
Aug 15, 2009 07:26 PM
thollis97
Jan 22, 2007 05:22 PM
Turbo EH2
Jan 1, 2007 09:17 PM
chicchocrider
Nov 3, 2006 10:30 AM
Yambor
Apr 29, 2005 10:55 PM
