Tranny problem..
Old Oct 4, 2012 | 05:01 PM
cryingsuns's Avatar
Default Tranny problem..
Okay so I don't know much about tranny's. Actually nothing. I guess my sycros's went bad where my half shaft go's in my tranny...I guess it's where a LSD would go. Now my mechanic wants to install a type R LSD but told me I need to purchase a GSR Gear ring. Where the hell do I get one of these things?
Old Oct 4, 2012 | 05:19 PM
slomofo's Avatar
GDD Member
Default Re: Tranny problem..
I think you're referring to the differential and not the synchros. What is the problem with your transmission? What I'm asking is, does it grind when switching gears or does it not go forward? Make noise?
Anyway, you can purchase a ring gear from any transmission shop in your area, possibly the Acura dealer, or search for "Y80 ring gear" on ebay, google shopping, or the forums.
Old Oct 4, 2012 | 05:32 PM
cryingsuns's Avatar
Thanks man for the response. Well I took my car to my mechanic and he was installing my half shafts and notice that my differential was causing my half shaft to jiggle a little bit. It's all loose up in the cavity where the half would go. And when I would drive it seems like something was loose every little bump or so, it sucked. So he offered me a type R lsd while it was open but said I need to get the ring gear. I found this one but it says cable so I'm not sure it's going to work. How much do these go for from the dealer?
http://www.ebay.com/itm/HONDA-CABLE-...a58894&vxp=mtr
Old Oct 4, 2012 | 05:33 PM
dirty19's Avatar
Ridin Dirty in Cali
Whhhhhhhaaaaaat?
Old Oct 4, 2012 | 06:05 PM
cryingsuns's Avatar
Originally Posted by dirty19
Whhhhhhhaaaaaat?
What do you mean bruv?
Old Oct 4, 2012 | 06:40 PM
slomofo's Avatar
GDD Member
Whhhhhhhaaaaaat?
Here's what I believe is happening, but I'm not certain (which is why I haven't made a 2nd reply):
  • OP went to mechanic to have CV axles changed.
  • Mechanic found freeplay in the differential.
  • Mechanic pulled transmission off, split the case, and is trying to sell OP a diff from an S80
  • Mechanic states that he cannot complete task without a Y80 ring gear.
  • OP is asking where he can purchase a Y80 ring gear.
  • OP found a YS1 ring gear on ebay and is asking if it'll fit.
I think that's what's happening here, but I don't know what kind of car this guy drives, what transmission or engine he has, so I can't be of much help.
OP, here's a GSR ring gear: http://thmotorsports.com/carbonetic/...1/i-37936.aspx
I have no idea whether it'll fit your car or not because I'm not sure what your setup is.
Old Oct 4, 2012 | 06:43 PM
cryingsuns's Avatar
I have a b18c1 with a 99-00 si tranny in an EG Hatch
Old Oct 4, 2012 | 08:53 PM
ElementzofR's Avatar
Same thing happened to my boys 2000 Si Tranny. He would be driving down the street and you could hear the differential kicking in the tranny. We popped out the axle and it was loose inside. We just got an ITR tranny and called it a day.
Old Oct 4, 2012 | 09:01 PM
dirty19's Avatar
Ridin Dirty in Cali
Thanks for clearing that up...
coreysef
Transmission & Drivetrain
Apr 21, 2011 10:43 AM
kenny_
Sep 1, 2009 09:40 PM
dcfreak
Sep 11, 2007 09:45 PM
Brian_92GSR
Mar 7, 2002 01:21 PM
