need help.....tranny problem
Old Sep 9, 2007 | 08:57 PM
dcfreak's Avatar
Default need help.....tranny problem
well my transmission was not going into gear and was leaking so i took it off and found a hole in the side of it. then when openin the transmission up the final drive pinion shaft was broken. the shaft has 14 gear teeth and the gear has 64 i have no clue on if its a type r or a b16 final gear so if any one can help that would be great i will try to get some pics up.
Old Sep 10, 2007 | 11:30 AM
Mista Bone's Avatar
D Tranny Guru
buy a new tranny........
diff pin explosion
Old Sep 10, 2007 | 02:55 PM
dcfreak's Avatar
Default Re: need help.....tranny problem (dcfreak)
can i still use my lsd then
Old Sep 10, 2007 | 11:24 PM
Mista Bone's Avatar
D Tranny Guru
LSD wasn't installed in the exploded tranny, why couldn't you use it?
Old Sep 11, 2007 | 05:58 AM
dcfreak's Avatar
no the lsd was installed.
Old Sep 11, 2007 | 10:44 AM
Mista Bone's Avatar
D Tranny Guru
then explain how the pinion shaft was broken.
Pics since your not describing the parts correctly.
Old Sep 11, 2007 | 09:45 PM
dcfreak's Avatar
found what i needed on another thread thanks for the help though..
jceltalentoso
Transmission & Drivetrain
May 13, 2014 09:05 PM
coreysef
Apr 21, 2011 10:43 AM
hfrex
May 14, 2009 03:20 PM
Brian_92GSR
Mar 7, 2002 01:21 PM
