Misfire - no acceleration
Hey guys having a lot of trouble trying to fix my problem.
B16A2 obd1
When I start up the car, it sounds fine at idle, but every 5-10 seconds, there is a slight pop as the engine misses. It is very slight, and you wouldn't notice it unless you were really looking for it. If I hold the revs higher, it's still there.
The main problem is that when the engine heats up after about 5 mins of driving, it won't rev all the way. If I hold my foot to the floor, the revs pick up for a bit, then at about 5k, the revs drop and drop until the engine almost stalls, then when I lift off, it returns to (almost) normal idle. It gets gradually worse too, until it won't rev up past 2k
If I turn the engine off and back on, it seems fine for another minute or 2, but then it happens again.
Things I have replaced.
Fuel pump
Fuel filter
Fuel pressure regulator
Fuel lines
Lambda sensor
Distributor
Ht leads
Spark plugs
Engine loom
Checked ignition timing - fine
Checked Tps and map are not mixed
No cel and no codes.
Fuel pressure is fine
Fitted a decat
Any ideas guys.
I have triple checked the basics like water, oil, throttle body, plugs, earths etc etc
What do you think?
Thanks.
B16A2 obd1
Fuel pump
Fuel filter
Fuel lines
Lambda sensor
Distributor
Ht leads
Spark plugs
Engine loom
Fitted a decat
Any ideas guys.
What do you think?
Thanks.
Cel works. I disconnected the map sensor to manually throw a code and tested it. - seems to be correct!
New cap and rotor. Ht leads are used, but tested on another motor.
Could be the ecu. Will test another one.
Andrew 825SM
Oct 20, 2004 09:52 PM
