leaking tranny fluid
So I pulled into the driveway today and as I went to walk in front of the car I seen smoke and smelt something. I popped the hood and didn't see anything. I then looked under the car and there was fluid on the ground. I the jacked the car up sprayed everything down with brakecleaner and saw that the tranny was leaking from the bottom. It never leaked before and I noticed that the fluid was underneath the car almost all the way to the exhaust. Is it a seal or what.
94 integra ls standard. Hydro tranny
I had the same problem. Turned out to be the breather box where the pcv valve goes. It was missing a bolt. Although I did notice a teeny bit of tranny fluid leaking from up top by the engine code
faster Type R
Honda Civic (2006 - 2015)
Nov 11, 2009 04:12 AM
JDMlyfestyle
Nov 1, 2005 03:59 PM
