MAJOR Clutch Problem...help
Last week the car wouldnt shift into second and third, like trying to shift without pressing clutch(most likely broken clutch spring). Today the clutch is loose and has no kick back what so ever. I can push the clutch peddle in with my pinky and it just drops to the floor, then I have to lift the clutch peddle back into place. Any input or advice would be appreciated. Luckly I have Sears Auto repair down the street.
Same thin was happening to mine , I kept losing lots of fluid but I didn't see anywhere that could have leaked but after I pulled back on that rubber housin on the slave cylinder a whole bunch of fluid came out. The o ring inside had torn and was leaking inthe inside by that little rubber cover was holding it all in
X2. Pretty common (sounds like you may not know where the reservoir bottle is) right next to the brake fluid reservoir and uses the same fluid (brake fluid dot3 or 4) if there is no fluid most likely your clutch master cylinder is leaking check under the dash..
