No timing mark on the oil pump
Old Oct 2, 2012 | 02:08 PM
Ej8_KiD's Avatar
Default No timing mark on the oil pump
Doing some work on a friends car and came across this , there is no timing mark on the oil pump , the motor is a d16y7. non oem pump i would assume? the #1 piston is at TDC but since there is no timing mark im unsure and i dot want to put everything back together untill i sort this out.
Old Oct 2, 2012 | 02:14 PM
94EG8's Avatar
Seagull Management
Default Re: No timing mark on the oil pump
It's an aftermarket pump. The keyway in the crank should point straight up at TDC, use that for a reference. It's not ideal, but if you have no timing mark there's not much else you can do short of replacing the oil pump.
Btw. the end of the crank looks chipped or otherwise messed up. Also, that oil pan gasket is torn and was probably overtightened when installed, there's also a sealant where it shouldn't be.
Old Oct 2, 2012 | 02:34 PM
fragmare's Avatar
Yea, just use the woodruff key as a reference. You could double check with the "screwdriver down the spark plug hole" trick.
If you really wanna be considerate to the next guy working on the car (which might still be you lol) you can take a dremel or something and make your own mark on the pump when you're certain it's TDC.
Old Oct 2, 2012 | 02:46 PM
Ej8_KiD's Avatar
Thank you , basically the whole car is a nightmare but she loves the car lol
Old Oct 2, 2012 | 02:47 PM
Ej8_KiD's Avatar
I thought about that but the no timing mark situation had me wondering for a while lol
Old Oct 2, 2012 | 03:48 PM
Axatax's Avatar
That oil pan is torqued *way* too tight (and unevenly), which is probably why the gasket is split under the oil pump.
Someone probably tightened it up when it leaked due to all that sealant preventing a good seal.
Old Oct 2, 2012 | 03:56 PM
fragmare's Avatar
Damn, yea... I didn't notice that. I think those bolts only go on at something like 9lb-ft. and in the proper sequence. That thing looks crushed down, hard. At least in the pic.
Old Oct 2, 2012 | 04:33 PM
Ej8_KiD's Avatar
She already ordered most of the gaskets so i'll be dealing with that soon enough , my concern was the timing mark on the oil pump
Old Oct 2, 2012 | 10:09 PM
fragmare's Avatar
When you go to reassemble, and have the crank pulley back on, just line up the TDC mark on the crank pulley with the notch/pointer on the timing cover. That way, it'll eliminate all doubt. From the pic you posted, though, it looks like you're pretty close if not dead on.
Fred Demara
Sep 12, 2012 09:18 AM
turbo-crx
Jun 9, 2009 10:31 AM
LobeSex
Apr 17, 2009 06:59 PM
JokerTypeR
10
Jul 21, 2006 12:56 PM
