99 civic ex coupe 5spd new radio no power locks
Old Oct 1, 2012 | 10:22 PM
GRNcivEX's Avatar
Default 99 civic ex coupe 5spd new radio no power locks
Hey
I have a 99 civic ex coupe 5spd
I bought the car this way, previous owner said the power locks stopped working after he installed the aftermarket radio.
I can still lock/unlock the doors individually with the key or individually with the levers on the doors.
When I try to unlock/lock with the fob the lights flash and I can hear a click inside both doors, but nothing changes with the locks or levers on the doors.
Also, when i lock the driver door from inside with the lever I hear a click in the passenger door, but again, nothing has changed.
I read that removing the factory radio could cause a loss of keyless entry up to 1998 but(if done properly) should not in a 1999 or later. Is this true?
I also read problems with power locks sometimes affect the dome light, but my dome light and other electronics still work.
Before I start taking the radio out and door panels off, any ideas of where I should look first?
Old Oct 1, 2012 | 10:49 PM
R8198EJ8's Avatar
Default Re: 99 civic ex coupe 5spd new radio no power locks
Here is the electrical diagram. According to this, the radio should not interfere with the door locks.
Old Oct 1, 2012 | 10:53 PM
R8198EJ8's Avatar
To start, check the fuses in the diagram.
Old Oct 1, 2012 | 11:12 PM
GRNcivEX's Avatar
Thanks for the diagram, should make things easier!
Old Oct 1, 2012 | 11:24 PM
Axatax's Avatar
Factory 5 speed or converted auto?
Old Oct 1, 2012 | 11:25 PM
GRNcivEX's Avatar
factory 5spd
Old Oct 2, 2012 | 11:54 AM
R8198EJ8's Avatar
Found this as well. Hope it helps.
Old Oct 2, 2012 | 06:49 PM
GRNcivEX's Avatar
Thanks, that does help.
I checked the fuses today and they're good
Old Oct 3, 2012 | 09:27 AM
R8198EJ8's Avatar
Did the previous owner happen to change the speakers as well?
Nisif
Nov 12, 2014 09:17 AM
Nisif
Nov 12, 2014 06:57 AM
gilheaven
Oct 15, 2012 12:20 PM
bcj3nq
16
Sep 23, 2010 12:20 PM
Hnda_Crx_Man
Audio / Security / Video
10
Aug 4, 2002 06:49 PM
