About swap da6+b18c to civic ed???
Hello broS...
I have some question about swap b18c in civic ed(ef, ee) 1989. Hatchback, d14a1 dualcarb.
I have civic ed!
) and yesterday I bought integra da6 (RHD, b16a, s1, 280mm front and 260mm rear disc) but now this integra with b18с+s1, and I also bought the s80...
here are my questions (non electro):
1. Do I fit the axles that stand now in the Integra (initially from b16a)? Or I need only driveshaft/hasport axles? I also want to use the front fists (hubs) kit of Integra with 282 brakes.
2. Do I fit mount kit from innovative/hasport to swap b18 into civic 89, which are sold on ebay.com? (I will be grateful for the link to the right offer)... Or I need 1 or 2 monuts, not kit? Mount transmission side, back mount and Cable>HYdro conversion? I think I can use integra engine side mount and all small Brackets with Rear T-Bracket.
Innovative kit: http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
3. Do I fit linkage that stand now in the integra?
4. Can I fit the integra's fuel tank with the fuel track? How about fit integra tank to civic ed? they are the same?
5. What exactly do I need for this swap? (with link, if you can)
I think my english very bad, sorry.
I have civic ed!
) and yesterday I bought integra da6 (RHD, b16a, s1, 280mm front and 260mm rear disc) but now this integra with b18с+s1, and I also bought the s80...here are my questions (non electro):
you will need a mount kit EFB2
shiftlinkage EFBLINK
axles EFBAX-HY
the rear engine bracket from a 90-93 integra will be needed and the bottom 2 holes will need to be drilled out with a 9/16ths drill bit
axles EFBAX-HY
shiftlinkage
axles???
CIVIC ED and Integra DA is one platform and one base.
What are the differences?
about mount kit I agree.
the shift linkage is not interchangeable. you can cut and weld the integra linkage to fit on the civic
there are 2 bottom holes on the rear T bracket. those need to be drilled out to accept the larger hydraulic transmission bolts
мне хаспорт похожее отвечали. ты тему не там создал. вот здесь ее создай. https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/
мне хаспорт похожее отвечали. ты тему не там создал. вот здесь ее создай. https://honda-tech.com/forums/forumdisplay.php?f=3
sam2135
Apr 11, 2018 07:49 AM
tinkerbell
14
Mar 27, 2004 05:55 PM
