d15b7 thermostat recommendations
Old Sep 30, 2012 | 12:40 AM
EG92DX's Avatar
Default d15b7 thermostat recommendations
What's up H-T. The other day I started my hatch in the morning and while looking at my radiator and the coolant levels I noticed the coolant was flowing... again the engine just started early in the morning , then I checked the temperature near the top radiator hose to the engine and it was 146 , climbed to 160 and stopped. I believe the correct temperature should be 190! Anyways , obviously my thermostat is shitted, what brand/model thermostat made for the d15b7 would you guys suggest?
Old Sep 30, 2012 | 01:25 AM
CO671's Avatar
Default Re: d15b7 thermostat recommendations
It's safe to run without it temporarily, so go ahead, remove it. and then use RTV / sealant to put the thermostat housing back together until you can grab a replacement.
Stant or Gates are fine, or just fork out extra for knowing you got OEM.
http://www.rockauto.com/catalog/x,ca...,parttype,2200
Old Sep 30, 2012 | 01:49 AM
fragmare's Avatar
I usually just go with a 170F (OEM temperature) Stant Superstat for my D15B7. Works fine for me. Never tried Gates, but I've heard they generally make quality stuff too.
Old Sep 30, 2012 | 09:15 AM
redm3turbo's Avatar
I get stant b/c whenever the go bad its closer to hit advance/pepboys/etc
Old Sep 30, 2012 | 09:25 AM
HondaPartsHero's Avatar
Technical Hero
I personally prefer OEM and they're not that expensive.
Old Sep 30, 2012 | 01:36 PM
EG92DX's Avatar
Can someone confirm if the stock temperature rating should be ~190 or ~170
Old Sep 30, 2012 | 02:35 PM
redm3turbo's Avatar
^ Id venture a guess stock is 190....
Old Sep 30, 2012 | 02:37 PM
fragmare's Avatar
It should start opening at 172F (+/- 4F), so 170F would be closer to the OEM temperature. The 180F stats will work fine, but they're mainly for D15Z1 engines.
This info from the Honda Service Manual.
1CiViC1
20
Dec 24, 2016 07:35 PM
tonylovesjdmEF9
Apr 8, 2012 11:08 PM
freefall365
Aug 30, 2010 10:47 PM
jwlee7ucla
Aug 7, 2007 03:48 PM
owen_the_soyboy
Mar 30, 2002 11:17 PM
