97 non-VTEC, no Spark, no idea
Old Sep 28, 2012 | 04:44 AM
StreetsideStig's Avatar
Default 97 non-VTEC, no Spark, no idea
Hey guys,
I'm out of ideas, here. I'm trying to fix my friend's 97, which isn't getting spark to the wires. It turns over fine. I've tested the coil, replaced the ICM, checked the cap, replaced the rotor. The distributor's fine.
It has to be wiring, right? I checked the coil and "ECM" fuses. (Is "ECM" another term for "ICM?")
Is there something I'm missing, or am I just not checking these things thoroughly enough?
Thanks!
-Andy
Old Sep 28, 2012 | 04:47 AM
jdmerda9's Avatar
Default Re: 97 non-VTEC, no Spark, no idea
So your saying you do have spark just not getting spark at the wires?
Old Sep 28, 2012 | 05:02 AM
I just did a standard spark test at the end of the wires. I didn't test spark at the coil, but I bench tested it and it looked fine.
So no spark at all that I know of.
Old Sep 28, 2012 | 05:09 AM
nealnanoHX's Avatar
Ok first need more info. What make and model are we talking about here? What motor? OBD2 or OBD1 conversion? Did it run before and just start acting up or was a swap just done? Do you have any CEL codes? Just going on what you are telling us I would check the dizzy and make sure it is getting power and ground and ECU signal.
Old Sep 28, 2012 | 05:14 AM
It's a stock, automatic 1.6 non-VTEC. I'm not sure what the designation is. It should be OBD2, though I haven't pulled any codes yet (should have done that first). It was running fine, and he started to see some shuddering, then after a couple of days, it died and refused to start.
I haven't checked the cam position sensor yet. It throws a code, right?
Old Sep 28, 2012 | 05:48 AM
jdmerda9's Avatar
Most likely its the dizzy ...a number of things can go wrong with it but in the end your better off getting a new one ....peice of advice not autozone ..it will save you alot of time
JuniorDDavis
41
Mar 5, 2012 12:43 PM
murray195
Jun 10, 2007 12:57 PM
EblazeK
Aug 4, 2006 01:02 PM
s2kkk
20
Apr 15, 2004 11:12 AM
95turbohatch
24
Apr 7, 2004 08:07 PM
