Rebuild or Low Mileage Used Engine
Old Sep 27, 2012 | 10:57 PM
Matt Kotyk's Avatar
Default Rebuild or Low Mileage Used Engine
Ok I have the option to either buy a used d15b7 engine for 800 installed with 130000 k on it from a junk yard. or do my first rebuild on my own engine. my piston rings are fried, but my head is in great shape. so how hard is it to replace the piton rings, do my head gasket, timing belt, and waterpump, so basically a full rebuild. this would be my first time doing anything like this, but i have always wanted to learn, plus i can get the parts at cost, so it will be half the price of the new engine. i would prefer to do the rebuild so any help would be great. tips, or a step by step guide if anyone is feeling really generous.
Old Sep 27, 2012 | 11:02 PM
furious94ls's Avatar
Default Re: Rebuild or Low Mileage Used Engine
Pick up the Helms manual for your specific car/engine. If you are mechanically inclined and have some friends to help you it should be okay to do.
Old Sep 28, 2012 | 06:52 AM
B20DelSol's Avatar
800 installed is not bad, only if it really runs and comes with a warranty. For my old D16y7 I estimated $600 without fluids and such for rebuild. This was just for parts (rings, Timing belt kit, gasket kit, etc.) and deglazing the cylinders my self. Expect more if you have the engine machined professionally. If you are going to pull the engine out, and have the money, do a swap or something. D16Z6 would not be that bad, or even B-series. If you stay non-vtec, you should not have to switch your harness.
Old Sep 28, 2012 | 02:48 PM
94EG8's Avatar
Seagull Management
You're better off buying a low mileage used JDM engine honestly. Junkyard engines are pretty hit and miss (especially D15B7s) JDM Source in Alberta is reasonably close to you and I know several people who have bought from them, all had good experiences.
Old Sep 28, 2012 | 04:57 PM
redm3turbo's Avatar
unfortunately, that is not a full rebuild....
and my vote goes to jdm low mileage used engine...better bang for your buck, especially if you dont know what your doing
jooky5
Jun 16, 2012 11:59 AM
xiLLtegRax
Aug 16, 2009 06:19 PM
J.B.
May 6, 2005 08:42 AM
92integraVTECgsr
Jan 11, 2005 12:28 PM
mugenracer
Aug 12, 2002 05:01 AM
