a/f numbers dont match
Old Sep 26, 2012 | 07:02 PM
orioncivic's Avatar
Default a/f numbers dont match
ok ive got more or less a poor mans type r, p28 w/s300. 800cc inj. I'm trying to setup a break in tune till I go boost. My problem is my a/f at my gauge does not match up for the a/f numbers in the hondata datalog screen. I have my wideband wired thru the eld with the resistors cut. The offset is at -.13. I notice that at certain areas( not all) my a/f dont match the datalog, I'll be at 14.5 on comp. and 13.5 on gauge. If I open the gauges screen and comare the a/f there it is dead on(with in .1 off). Anyone else seen this?
Old Sep 26, 2012 | 09:23 PM
mtber's Avatar
Default Re: a/f numbers dont match
What wideband are you using?
What settings are you using for voltage vs air fuel ?
Old Sep 28, 2012 | 06:37 PM
orioncivic's Avatar
I'm using a aem wideband, the voltage offset is -0.2. and the voltage/lambda conversion table is 0.00 voltage=10.00 a/f, 5.00=20.00 a/f, and 5.00=20.00 a/f. ( that is 3 columns for that table.) not sure why the factory setting has the same numbers twice for the 5.00=20.00 ratio, should the middle be changed to 2.5=15 ?
Old Sep 29, 2012 | 02:53 AM
mtber's Avatar
Try 0 volts = 10.00 and 2.29 volts = 14.70 a/f and 5 volts = 19.98 a/f
What input are you using on the ecu?
Old Sep 29, 2012 | 07:28 AM
orioncivic's Avatar
eld with r136 and r138 resistor cut. I'll try the new input this afternoon. Thx btw anything going on car related in tampa area between the 5 and 13 of oct.? I'm going to be in dunedin then.
Old Sep 29, 2012 | 09:49 AM
mtber's Avatar
IFO is Oct 7th
www.importfaceoff.net
The ELD input should work fine with the settings I suggested.
Old Sep 29, 2012 | 07:18 PM
orioncivic's Avatar
ok thx, gainsville is a little out of the way.... ill check out the new settings tomorrow. Thx again
ZCHondaCRX91
Engine Management and Tuning
Aug 22, 2013 06:59 AM
MidwestAutoWorks
Nov 20, 2007 02:06 PM
RTW DC2R
Apr 2, 2004 11:40 PM
gamakichi77
Mar 30, 2004 09:33 PM
_Endless_
May 6, 2003 06:36 PM
