Will this actually work?
I came across this picture on AJ's site. Will this thing actually aid in preventing wheel hop?
[Modified by RaVAGE00, 11:19 AM 10/17/2002]
[Modified by RaVAGE00, 11:22 AM 10/17/2002]
[Modified by RaVAGE00, 11:23 AM 10/17/2002]
Stiffer engine mounts reduce wheel hop and this seems to do te same so I would say yes i will reduce wheel hop, by how much I don't know. Just my 2 cents
All those peices there look exactly like my EK, so I dont see how RHD or LHD should matter.
OK i called AJ Racing...not sure who I spoke to, sounded japanese. Anyway wasnt the easiest to understand, but the one they installed was on an EK. He said the ones they have are ONLY for the EK, not the DC chassis. He said he is going to check Japan to see if they make it for the DC or not. Atleast thats what I got from the conversation haha.
To answer some of the questions raised:
There are no clearance issues with uncut valve covers, the car in the picture now sports an uncut cover and everything is fine
As for fitment, the DC2 version of this unit mounts differently than the EK in the picture. The way that the DC2 version mounts on a LHD car would put it in contact with the master cylinder, hence the fitment problems. We're still working on a way to mount it though.
The effect with the torque dampener is noticeable. Driving feel is quite improved... feeling is more direct and stable... less sloppy.
Have you looked into if the mounting brackets that J's Racing uses will work on US DC2s? It looks like they use the Mr. Alex unit, put their own sticker on it, then mount it in a different location.
I think it would be more effective near the IM behind the CG of the motor, as high up as possible. Not sure, but if there are any extra threaded holes on the head above the IM, assuming it would clear to the firewall that would be the ideal location.
i like all the stuff j's racing stuff makes. i'm really looking into that bar that connects behind the fender. check it out. i dont' have a link tho but its pretty nice.
Razr2
Jun 22, 2008 07:52 AM
BojeEM2
Honda Civic (2001 - 2005)
Mar 29, 2007 09:09 AM
Mad Money
19
Mar 24, 2006 06:08 PM
I found it
