Skunk2 alpha question
2009 si, does the alpha have both o2 sensor holes? And also wondering if its bad paired with Injen Sri, my buddy has a megapower and had tons on heat soak when he had his shortram on, will heat wrapping them be enough to stop heat soak? Will probly invest in a Cai after, just wanna know If Injen Sri + heatwrapped alpha will cause a lot of heat soak or if the heatwrapwill help alot
the stock photo shows it has both o2 bungs. the sri will still heatsoak even with the header wrapped. that's what happens when the filter sits right next to it.
I am not sure if heat soak will be worse on a wrapped header. The stock one comes with a heat shield to prevent radiating heat, but a wrap would do the same. I would imagine if the CAI came with a heat shield or some way to isolate the filter from the header, the radiant heat soak would be reduced.
