To Replace LCA or LCA bushings?
Old Sep 24, 2012 | 11:44 AM
RanCRX's Avatar
Default To Replace LCA or LCA bushings?
Howdy,
I have a 90 CRX Si with b16a, and the car is lowered with h&r sport springs (with tokico blues).
But anyway if that helps, my Lower Control Arm bushings are shot to wear they can jiggle with no load. My question is, would it be cheaper and/or easier to replace the control arm, or replace the bushings? I have access to a shops press (2 of them) but I hear it may be difficult to get the bushings to slide out.
Let me know what's up!
Old Sep 24, 2012 | 11:49 AM
RanCRX's Avatar
Default Re: To Replace LCA or LCA bushings?
My fault. The reason I asked cause they have aftermarket LCA's for sale such as Moog and etc that are decent quality and I'm sure they'd sell them with exact specifications to meet the same angle and length requirements as an OEM part otherwise it would never make it to being sold, if it failed testing.
Otherwise, my old LCA's are good, but need some bushing upgrades. Planning to put oem bushings in those if not replacing the LCA itself.
Old Sep 25, 2012 | 10:24 AM
xxOldschoolxx's Avatar
I recently changed my bushings it was a PITA but it wasn't hard just time consuming.
First I pressed out the metal center piece then I had to cut the metal sleeve that encases the rubber part of the bushing and then I pressed that out. Just ask the shops around you to see how much they charge. Around me the shops wanted to charge 50/ LCA so I said screw it ill but a press instead.
Old Sep 25, 2012 | 04:16 PM
v4lu3s's Avatar
RTFM
link to moog rear lower control arm?
Old Sep 25, 2012 | 07:07 PM
Nooch's Avatar
http://www.ebay.com/sch/i.html?_nkw=...arms&_osacat=0
Old Sep 25, 2012 | 07:16 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
if those control arms have good quality rubber with equal durameter, i don't see a reason not to get them, matter of fact, i might get a couple myself.
Old Sep 25, 2012 | 07:20 PM
Nooch's Avatar
Nevermind my previous post, cannot find what he was asking for...
Moog on the other hand is a quality aftermarket parts company from the many reviews I've read.
I'm currently redoing a lot of my suspension with their parts so hopefully it works out well.
Old Sep 25, 2012 | 09:45 PM
BCGARAGE_ED7's Avatar
You could get Function 7 LCA's because they're lifetime warranty, so you wouldn't have to worry about the bushings going bad again.
Posted from Honda-tech.com App for Android
Old Oct 5, 2012 | 07:14 AM
RanCRX's Avatar
My fault. I ended up getting oem bushings for the front lca's since the only place i can find moog bushings which were in UK so shipment price equaled oem price. I got Moog front lower ball joints and also oem rear trailing arm bushings.
I gotta buy some for the rear lca.
Old Oct 7, 2012 | 09:10 PM
Grover Edmonds's Avatar
It is is just as cheap and easier to change the LCA.
Old Oct 7, 2012 | 09:13 PM
Tyson's Avatar
mmm fresh.
i think i paid $115 for the pair. this was a few years ago tho.
oresama
Apr 15, 2012 07:54 PM
BSM 135i
Acura TSX
Oct 28, 2010 04:44 AM
opeth13
Suspension & Brakes
Feb 3, 2006 12:10 AM
92LudeSR
Jan 6, 2006 02:30 PM
