Crank Pulley needed for d16a6. Underdrive? or Dampened?
Old Sep 23, 2012 | 10:53 PM
Vagitarian's Avatar
Icon6 Crank Pulley needed for d16a6. Underdrive? or Dampened?
Hey guys. I am building a d16a6 motor I have for boost. The crank pulley is missing and I need a new one.
I remember the oem d16a6 pulley I had for this crank not being dampenned, but Ive searched some good info on a damepened pulley being a good investment to save my bearings.
Is there any oem honda pulleys that will bolt up to my d16a6, and use the same timing and tdc marks??
I was also thinking of going with an underdrive pulley, since my oem pulley isnt dampened, I figued a one belt underdrive pulley could be a feasible option? It had visible timing marks on it aswell, but Im unsure if they were in the correct spot for a d16a6 so I can set timing correctly on first start up and adjusting
What pulley would you guys recomened?
Old Sep 24, 2012 | 06:51 AM
BiGZ's Avatar
Default Re: Crank Pulley needed for d16a6. Underdrive? or Dampened?
one from a d16a6...
Old Sep 24, 2012 | 08:39 AM
Vagitarian's Avatar
Why not a dampened one?
Or a lightweight pulley even since the factory pulley isnt dampened?
Old Sep 24, 2012 | 10:36 AM
4drEF's Avatar
Keyboard Humorist
A dampened one would not be a bad idea.
Out of the OEM lineup, the Y8 is supposedly the best built as far as d-series damper goes.
However there are a lot of boosted A6's out there with the stock pulley. So logically the A6 one should work just fine.
I would stay away from underdrives and non-damper aftermarket.
Way to many failure threads to show them to be a bad idea.
I don't think there are aftermarket D-series damper one similar to the ones Fluidampr makes.
Old Sep 24, 2012 | 11:24 AM
Vagitarian's Avatar
If I just bolted up a y8 pulley, would it use the same timing mark and tdc mark as a d16a6??
Im a noob to engine building and timing and this engine build and initial timing setting will all be a first for me when the time comes. So crazy mis aligned timing marks would probably hinder a noob on his first attempt
Id like to get the dampened pulley, y8 sounds good but the timing marks I cant find any info on. I noticed fluidamper makes a pulley for the d, but it probably has off timing marks aswell, and its $400
thanks for your help
Old Sep 24, 2012 | 11:35 AM
4drEF's Avatar
Keyboard Humorist
I know the marks on the Y8 and A6 to be the same.
The Z6 is rubber filled as well, but I'm not sure on the marks with that one.
Old Sep 24, 2012 | 12:59 PM
Vagitarian's Avatar
Well I just read that the a6 and y8 is base set at 12 degrees, where the z6 is 6 degrees.
So the y8 will essentially be a bolt on mod, no worrying about timing or it being off.
I read that it may be a different diameter than the a6 and I may need a new alt belt
Old Sep 25, 2012 | 01:12 AM
Vagitarian's Avatar
correct me if im wrong
Old Oct 18, 2012 | 12:23 AM
Vagitarian's Avatar
bump, i need to order a pulley asap
danteisme
Mar 27, 2016 03:15 AM
aragorn1023
May 30, 2010 06:28 AM
ONEQWKSI
Mar 30, 2009 08:26 PM
airsoft
Aug 6, 2006 04:49 AM
boomslang
Jun 16, 2003 06:24 PM
