Not makin power goals..suggestions
Old Sep 23, 2012 | 08:29 PM
BigheadMotorz's Avatar
Default Not makin power goals..suggestions
Set up is Gsr 81.5, springs,valves, port polish head,skunk2 tuner 2s, 70mm throttle body, custom top mount, 72mm BW, C.O.P.. Car isn't making over 460 @21lbs up the boost to 29lbs made 580. Everything looks good on the Dyno. Not sure if I should of degreed the cams or not but I guess I have to do a leak down just wanted suggestions
Old Sep 23, 2012 | 08:47 PM
locash's Avatar
Default Re: Not makin power goals..suggestions
More info..
What fuel, fuel system, injector duty, exhaust backpressure, datalog, etc?
Old Sep 23, 2012 | 08:53 PM
Sorry, Id 1000s, walbro intank w/Bosch before fuel rail, C16, 1.10 back housing. Not sure of injector duty. Felix tuned
Old Sep 23, 2012 | 09:09 PM
narfdanarf's Avatar
map sensor fucked up?
Old Sep 24, 2012 | 12:41 AM
hybrdthry911's Avatar
Dyno graphs would help too. Is VTEC definitely working?
Old Sep 24, 2012 | 03:57 AM
It's a full Gsr motor and one thing I noticed is I originally tuned with stock Gsr cams and made about the same power, installed the skunk2 and no difference.
Old Sep 24, 2012 | 04:18 AM
NA James's Avatar
What turbo?
Old Sep 24, 2012 | 04:33 AM
BW s372
Old Sep 24, 2012 | 04:34 AM
heavy duty's Avatar
What dyno?
Old Sep 24, 2012 | 05:35 AM
Dynojet
Old Sep 24, 2012 | 11:37 AM
allmotorbubble's Avatar
Which felix tuned it? And whos dyno was your car on?
Old Sep 24, 2012 | 11:48 AM
Gato and at 1320
Old Sep 24, 2012 | 03:02 PM
My car made **** power on erics dyno but put up great numbers at the track, put your car on a different dyno and you wont be disappointed
Old Sep 24, 2012 | 03:03 PM
locash's Avatar
BTW - According to the datalog, you're out of injector also..
Old Sep 24, 2012 | 04:42 PM
miller's Avatar
What does the graph look like?
Old Sep 24, 2012 | 04:50 PM
artie89's Avatar
one of my boys just had this same problem with this same turbo come to find out the coupler from the turbo to intercooler piping came off alittle bit fix the problem and made 751 at 29psi
Old Sep 24, 2012 | 05:28 PM
ls_on_boost's Avatar
x2 i gained 50+ hp from a small leak i had from a leaking coupler
Innes
Jul 17, 2013 01:47 PM
DA_JDM
Jun 3, 2007 08:21 AM
-Championship-
Jul 5, 2006 01:04 AM
mafay2
Mar 1, 2002 12:27 AM
