Need help with body panel description!
Old Sep 23, 2012 | 05:21 PM
MyNamesMatt's Avatar
Default Need help with body panel description!
Hi everyone,
I recently acquired a 1993 civic hatchback and when I went to take the rocker panel guards off they were starting to rust near the rear wheel. I am ordering new rocker panels to weld on, but I was wondering what the bottom portion of the rocker panel is called. It is rusted pretty badly as well, but when I went to look at a picture of the panel from fixmyrust.com it didn't seem like the bottom portion was considered the rocker panel.
This portion, that is rusted and seperated from the car is the rocker panel, correct?
but the part that would be directly underneath it, if you were to lie down under the car and look straight up, would be considered what..?
I know that it needs to be sealed/rewelded to pass saftey, because of body integrity and the fact that fumes can get in the car.
Just curious as to how these are fixed/what the panels are actually called.
Hopefully I can get some input, it would be great.
Thanks,
Matt
Old Sep 23, 2012 | 05:49 PM
lazlong's Avatar
Default Re: Need help with body panel description!
Wouldn't that be the floorpan? Maybe you can identify that part with an OEM parts catalog: http://www.hondapartscheap.com/index.php?p=home
Old Sep 23, 2012 | 06:07 PM
I took a few pictures of it, figured it'd be easier
I'm uploading them now on my iphone, it'll take a few minutes.
Old Sep 23, 2012 | 06:14 PM
Here are the pictures...
I tried sealing the rust patches on the end and I am ordering rocker panels because I figured it'll be best to do it PROPERLY. However, I don't know what to do about the bottom! Do I just seal it? Does the rockers from "fixmyrust.com" come with the bottom portion attached to the rocker? Any help would be great.
Does this look like it can't be fixed..?
Old Sep 23, 2012 | 06:29 PM
lazlong's Avatar
Yeah, looks like it might be the the sill (#23) but, a little is on the floorpan (#22 which includes #23): http://www.hondapartscheap.com/parts...ng/inner-panel
And the rocker panel (#1): http://www.hondapartscheap.com/parts...ng/outer-panel
Old Sep 23, 2012 | 06:38 PM
Great thanks a lot. The floorpan is really just surface rust, the entire floor plan, interior, and exterior for the most part is mint, just the rockers (and I guess the sill's) need work. So #23 and #24 with some rockers from fixmyrust.com (cause they're $40 and should do the trick) will work?
Old Sep 23, 2012 | 06:45 PM
lazlong's Avatar
I'm not 100% sure but, I think it's the sill. It's the only part I can find that could be it.
Old Sep 23, 2012 | 06:57 PM
Yeah I think you are right, but hopefully someone can chime in and confirm it. Thanks a lot for your help I really appreciate it.
Old Sep 23, 2012 | 07:27 PM
redm3turbo's Avatar
i think its a sill also.
and..that is more then just surface rust.
Old Sep 23, 2012 | 09:35 PM
On the floorpan? It's pretty stable, a screw driver and a hammer doesn't even put a dent in it... the Sill and Rocker on the other hand...... lol.
flamingdragon
Welding / Fabrication
16
Jul 6, 2015 02:47 AM
exz0n-.-
Paint and Body
11
Nov 2, 2008 09:16 AM
mgcivic359
Nov 9, 2006 09:42 AM
JmurGSR98
Dec 15, 2005 10:52 AM
95GSRTT
Oct 2, 2004 09:47 AM
