Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
OBD sensors not resetting
Old Sep 23, 2012 | 04:24 PM
MrArt's Avatar
Default OBD sensors not resetting
I have a 2005 Accord EX (4 cylinder) with a little over 6K miles (yes just 6K)on it. I had to disconnect the battery to charge it so I could drive to a smog station. Naturally I failed the smog test “This vehicle failed the MIL/CHECK engine light due to failure to successfully complete all OBD tests” I drove the car through 5 or 6 drive cycles and can’t reset all the sensors. I even installed a new battery and started the drive cycles again (some 200+ miles).
I am using a ElmScan 5 scanner and OBDwiz software. The OBDwiz Monitors/Monitor tests gives me the following incompletes:
EVAP Monitor Available Not Complete
Secondary Air System Monitor Not Available Not Complete
Air Conditioning Monitor Not Available Not Complete
Heated Catalyst Monitor Not Available Not Complete
There are no P codes
Is there some specific driving cycle I can do to reset these monitors?
Any thoughts would be appreciated.
Old Sep 23, 2012 | 04:34 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: OBD sensors not resetting
The only monitor not set is the Evap. You can pass the smog test in CA with 1 monitor not set. Dont know where you are. The other monitors are not applicable to your vehicle. (BTW, EVAP monitors tend to be hard to set)
Old Sep 26, 2012 | 06:37 AM
MrArt's Avatar
Thank you
I didn't know the other tests didn't apply to my car. I'll take it back to be retested.
Thanks again
Art
^XpLiCiTxX^
83
Oct 2, 2013 04:27 PM
Philsy
May 29, 2007 06:29 PM
hatchi
Northern California (Sales)
Jul 8, 2006 03:52 PM
SYTFU Tommy.
Aug 13, 2004 07:14 PM
