High Comp for B16
Old Sep 23, 2012 | 04:10 AM
osamazx's Avatar
Default High Comp for B16
Hi All
I Have Honda civic with swap engine B16A i am looking to change stock b16a pistons for high Compression 82mm pistons should this make difference , is it worth it or not ?
Old Sep 23, 2012 | 05:18 AM
grumblemarc's Avatar
The Grumpiest
Default Re: High Comp for B16
Make a difference in what? Kinda wondering why you're going to do this if you don't know the outcome.
Old Sep 23, 2012 | 05:42 AM
JuggerNaut-CTR's Avatar
why 82mm...
Old Sep 23, 2012 | 07:44 AM
Former User's Avatar
What Civic? What B16A engine? Tech threads require specific car/engine information.
Old Sep 23, 2012 | 09:57 AM
nealnanoHX's Avatar
Increasing compression and displacement will increase output but only if you have the cams to take complete advantage of the increased compression. Personally I would just go to a B18B block with P30 pistons a good bottom end that will make tq and power even with small B16 cams.
Old Sep 24, 2012 | 02:04 AM
osamazx's Avatar
Why 82 ? Because you you have to bore B16A block and i don't wanna make it weak ...
i know the outcome but i need advice if this will be worth it ... since it will cost you money and time as you know
Old Sep 24, 2012 | 02:30 AM
The Grumpiest
I'm sorry. WHY do you "have to" bore the B16? You aren't providing enough info.
Old Sep 24, 2012 | 02:44 AM
jbpnoman's Avatar
More precisely, you aren't providing us any information. Tell us what you're aiming for. Of course high comp pistons will make a difference - if they didn't, all motor builds wouldn't be running 11, 12, or even 13:1 compression on the track. If you didn't know that high compression makes a difference, you have a lot more to read up on before you worry about "having" to bore anything out.
We don't play cat and mouse on the tech forums. Ask us precise questions, and we'll give you precise answers. Ask us wishy washy, open ended questions, and you won't get any useful response.
Old Sep 24, 2012 | 03:10 AM
osamazx's Avatar
Sorry for that
My Setup like the following :
Golden Eagle Fuel Rail
Spoon Chip
Skunk Throttle 70
Skunk2 Camshaft stage 2
Walbro Fuel Pump
Fuel Regulator
Light Weight Pulley
Light Weight Flywheel
4-1 Headers
And other information should i post ?
Old Sep 24, 2012 | 03:24 AM
jbpnoman's Avatar
First off, get rid of that "Spoon chip". It's garbage, and if you want to see actual power gains without the risk of grenading your motor, you need to get your car properly tuned. Second off, what specifically do you want to know about high comp pistons?
Old Sep 24, 2012 | 03:27 AM
osamazx's Avatar
I know i will change it
i want increase power without using turbo but i don't know if i waste money in right place
Old Sep 24, 2012 | 03:46 AM
jbpnoman's Avatar
The only way to make competitive power without a turbo is with sleeving, boring, stroking, and compression. The first thing you should be worrying about is finding a reputable machine shop to install some Darton or AEBS sleeves. While that's being done, start educating yourself about stroking and compression. There's a lot of math involved in building high output motors. You have a lot to learn. Start off here.
I'll say it again. You aren't going to make competitive power out of that motor without a LOT more money.
Old Sep 24, 2012 | 04:54 AM
osamazx's Avatar
Thank you very Much Man very Useful
xelhefe
14
Sep 4, 2011 01:37 AM
Chief Wenceslaw
10
Mar 17, 2006 03:44 PM
Lou_EM1
11
Feb 22, 2006 06:32 PM
1G_DX_to_2G_Si
Nov 10, 2005 04:37 PM
minivan81
Jul 20, 2003 01:14 PM
