Is my alternator bad?
94 Civic Si
JDM B16A OB0
Had this car for 17 months
Was driving on the highway for about 3 minutes at 3K RPM going 60mph. Then was slowing to a red light I put my transmission in neutral and I just saw my rpm hit 0
So I got her started with the help of a fellow driver via push start. The car tried to die a couple times whenever I put the car in neutral to slow down at a traffic light so I just held my RPM's near 2000RPM.
Battery light is NOT on
Voltage at idle (900 RPM)with no accesories on: 12.65
Voltage at 2000 RPPM with no accesories on: 12.81
Volatge at idle with headlights, defroster, radio, and domelight on: 11.68
Is there any other tests I can do?
if it is my alternator...I don't know which one to order since I have a JDM B16A and the alternator?
JDM B16A OB0
So I got her started with the help of a fellow driver via push start. The car tried to die a couple times whenever I put the car in neutral to slow down at a traffic light so I just held my RPM's near 2000RPM.Battery light is NOT on
Update: It's not my alternator...
I looked at some alternator threads and I found one where the guy was having the same problem as me. When he changed his alternator he was still getting the same amount of volts.
So I didn't buy an $100+ alternator. I did some more troubleshooting with the charging system. Alternator fuse is good...continuity from alternator connector to battery post shows good and only had .002 of ohms. Next was to look at my grounds. ALL OF THEM WERE CORRODED!
I cleaned the grounds up especially the G101 which is at the thermostat. Did a parastic draw test...results 3ma of draw compared to when I tested it like a week ago it had 7ma of draw.
Tested the battery volts and it was at 12.30 not really good in my book but the car started like it was healthier than before.
Idling with no accessories on: 14.28 volts
idling with headlights, defroster, ac, and radio on: 14.10 volts
Now time to go driving around and see how she does.
TorWheeler
Dec 9, 2012 01:10 AM
