92 civic si - check engine light codes
I have a 92 civic si with integra dash in it when I bought the car I recently replaced the the check engine bulb cause it was out now it wont shut off I put a wire in the jumper and its flashing now made a video check it out any help is needed thanks F$@+ SMOG
http://youtu.be/uZmhGkFzaW0
Re: check engine
thats weird cause its manual could it be wiring? electric load detector wat would cause that
I been driving it around for month with no problems just the speedo dont work and the check engine now
Re: 92 civic si - check engine light codes
sounds like an automatic ecu
what ecu is it?
just cause its stick now doesnt mean it wasnt automatic before you owned it bud.
auto to manual swaps are very possible and very easy. and very hard to identify one that has been swapped unless carefully inspected or via vin number check.
what ecu is it?
found out I do have auto ecu I changed it to stick now my light comes on after 10 mins after driving but turns off if I restart car
[QUOTE=Rickdogg;47904880]found out I do have auto ecu I changed it to stick now my light comes on after 10 mins after driving but turns off if I restart car[/QUOTE
NICE!!!
now what you need to do is jump the 2 wire connector and see what codes come up.
http://check-engine-light-codes.blog...retrieval.html
NICE!!!
