Opinions on Wheel Spacer's
99 Coupe w/2inch Drop steelies on the front, would like to get a Wheel spacer kit 4x114 so the front is a little wider stance, maybe 5mm @ most i need to measure first But i was just wondering if any of you have spacers and how did they affect your handling etc?
also, i would want to buy the "spacer" and the extended Lug's , the Bolt on hub kit from ICHIBA Doesn't look so safe with the little bolts and Nuts they got going on there..
5mm is too thin to have a spacer with studs. Usually ~25mm spacers are what come with studs. The clamp force of a properly torqued lug nut will be fine. It's the friction between the components that prevents the wheel from moving.
gakkuken
21
Jan 10, 2005 02:28 PM
