RPM's jumping
Old Sep 21, 2012 | 06:56 PM
Domani99's Avatar
Default RPM's jumping
GSR motor. Suddenly car started jumping RPM's. When i firs start it, the RPM will go to about 4000rpm. Then when its at idle it will go up and down from 2-4000.
Cleaned the IACV. Unplugged it while the car is running and it wants to die so I think that's a sign that it works.
Any Ideas?
Old Sep 21, 2012 | 07:21 PM
Mr_Ferio's Avatar
Default Re: RPM's jumping
Check your TPS sensor.
Old Sep 22, 2012 | 02:56 PM
Domani99's Avatar
Tested TPS today an it came back @ .55v-.56V Sprayed carb cleaner around the TB and the IM gaskets and no change in the revs.
Old Sep 22, 2012 | 02:59 PM
EK_GSR_FL's Avatar
Check sparkplugs and wires?
Old Sep 22, 2012 | 03:11 PM
Domani99's Avatar
hmm. Didn't think to check that. Thought that would cause misfires or low idles. Not erratic idling. Guess I can go check it. How to I test the Dizzy?
Old Sep 22, 2012 | 03:31 PM
EK_GSR_FL's Avatar
Mine was bouncing back and forth and turned out to be a a bad plug. doesnt hurt to give a quick check.
Old Sep 22, 2012 | 03:36 PM
Fliptard's Avatar
Mine does the same thing, I made a block off for the IACV outa a thin piece of sheet metal that just goes between the sensor and IM. Idle stays at around 1k now.
Old Sep 22, 2012 | 03:55 PM
Domani99's Avatar
So why not just replace the iacv? Is that what is wrong with yours.
And yea I will test for spark.
Old Sep 22, 2012 | 05:16 PM
mathai's Avatar
Did u check all your vaccum lines?
Old Sep 22, 2012 | 08:24 PM
Domani99's Avatar
Lines were fine however a Pipe Plug fell off my manifold... Just fixed it Thanks for the help everyone.
Funny how something so small causes a big headache..
brant
Mar 29, 2011 06:43 PM
Circaskaterr
Jan 26, 2010 08:09 PM
slowB20ej8
Jan 3, 2008 09:42 PM
digitalspice
Feb 20, 2002 02:35 PM
