93 civic ex timing issue!!!!
Old Sep 21, 2012 | 04:57 AM
redmondracing's Avatar
Default 93 civic ex timing issue!!!!
i have a 93 civic ex with a d16a motor it will run with the distributor anywhere as rotating it goes but has no power unless advanced completely!? and also sucks gas like a v8 any help or advice would be appreciated.
p.s. going to tear apart the timing belt side of the motor this weekend to make sure the timing is aligned right!
Old Sep 21, 2012 | 10:14 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: 93 civic ex timing issue!!!!
so...do we answer your question since your tearing it apart?
did you clean the rotor and noids out in the dizzy?
Old Sep 21, 2012 | 10:18 AM
fragmare's Avatar
Are you ABSOLUTELY sure the mechanical timing is correct?
Is the dizzy OEM or aftermarket?
Are you sure the correct timing belt is installed (they come in two flavors, 103 tooth and 106 tooth)
Was there a head swap done on this motor?
Old Sep 21, 2012 | 10:57 AM
I'm not Rick!
^those are good quesitons..
Old Sep 22, 2012 | 04:01 PM
oem distributor and idk about the belt 103 or 106 tooth and im absolutely positive the mechanical timing is on checked it today. also cleaned the point on distributor cap!? should i tear apart the distributor and check the internals connections etc? thanks for the reply though
bnwbass
May 14, 2016 12:37 PM
zx92027xz
Aug 11, 2012 06:47 AM
DrewDown
Nov 18, 2004 07:05 PM
handa
Jul 30, 2004 11:19 PM
